It is currently Sun Oct 11, 2026 10:46 pm
PostPosted: Thu Aug 27, 2020 4:02 pm
Ok y’all, doing the late 70’s AC bracket swap. Moving along, until I found out the two groove pulley doesn’t fit with the later style configuration. Did the later AC’s just use the single groove pulley? If so, do all slant pulleys interchange?
PostPosted: Thu Aug 27, 2020 5:06 pm
What two-groove pulley, later configuration of what, which slant pulleys?
Crank pulley
Water pump/fan pulley
Alternator pulley
A/C compressor pulley
PostPosted: Fri Aug 28, 2020 7:38 am
The ac cars use a two groove wp pulley, and I made the swap over to the late 70’s AC mounting and didn’t realize , the wp pulley is different . Wanting to know if the single groove’s interchange from year to year? Anyone perhaps has done this swap and can confirm this is what I need. My pulley interferes with the idler.
