It is currently Sun Nov 29, 2026 7:13 pm
PostPosted: Mon Aug 02, 2004 3:47 pm
Username is vehicle in question with a /6, Ive done radio swaps, swapped alternators, grounded the radio, grounded everything else, even installed a noise suppressor on the Alt. Power line and then swapped it to the radio power line and I still get interference that varys with engine speed. If I disconnect the Alt power line the noise stops, What can be causing this and what do I do to make it stop? Im at my wits end with it!!!
 Post subject: Radio interference
PostPosted: Thu Aug 05, 2004 9:03 am
Sounds like you have a leaking diode on the alternator rectifier circuit. Do you know that the second alternator you installed was operating properly or could it be plagued with a problem the same as the first one? RMDV
Carl Zeamer. an old guy, please be gentle.
Users browsing this forum: Rick Covalt and 1 guest
