It is currently Sat Jun 13, 2026 12:42 am
Post new topic  Reply to topic  [ 1209 posts ]  Go to page Previous 134 35 36 37 3881 Next
PostPosted: Thu May 04, 2023 4:37 pm
I believe Slantzilla has some kind of response AI device that helps him come back with very intelligent responses!
He is not the only one who does not care for fine Italian carburetors.
PostPosted: Thu May 04, 2023 5:59 pm
Well, I can't argue with most intelligent people, but there is no doubt that Webers can work and work well. I am living proof that they can be made to work with a relatively low IQ. :D I guess when you bolt the 4 barrel back on it will reveal whether the carbs are to blame. Keep at it.
PostPosted: Fri May 05, 2023 5:39 am
I believe Slantzilla has some kind of response AI device.
I think Slantzilla is a responsive AI device...
have you ever met that guy?
:D
PostPosted: Fri May 05, 2023 2:22 pm
From the way the car runs I woulda guessed 5220..............
PostPosted: Fri May 05, 2023 3:20 pm
So cruel and so funny at the same time! :D :D Sorry Stan.
PostPosted: Sat May 06, 2023 3:32 pm
It's ok, I deserve the punishment.
PostPosted: Sun May 14, 2023 11:27 am
Transmission is ok, everything looks ok.
I did some thinking on the shifter, may have found a little help there.
Like the other problems I have addressed, won't know till some track time.
This is the 1-2 shift pin that runs in the slot and drops into the gate to shift 3-4.
It's pretty shallow to me, so I moved it forward.
I got stuck in 2nd at MOKAN.
Weird.
PostPosted: Sun May 14, 2023 11:34 am
I spoke to Dave Mueller today on the phone.
Man is he sharp and doing still some great things with slants.
Boy I wished I was closer!
PostPosted: Sun May 14, 2023 1:09 pm
Cool! Dave is a great guy.
PostPosted: Sun May 14, 2023 1:44 pm
Dave said he wanted a piece of you..........
Well I said that, not him.
Would that be cool or what?
PostPosted: Mon May 15, 2023 4:00 am
That would be something to get his 36 and my 34 on the track together. I would have to build a better motor or upgrade/tune this one to beat him if he's running mid 13s. Prolly run high 13s now at a track like Woodburn...
PostPosted: Mon May 15, 2023 5:04 am
Dave has some cool stuff fo' sho'
I have never met him unfortunately.
What kind of shifter are you running there Stan.. Looks unfamiliar to me.
PostPosted: Mon May 15, 2023 5:45 am
Hurst Ram Rod.
It's an inline shifter, not an H pattern.
Has a separate Reverse Lever.
You lift a lever to engage 1st and then it's just back, forward and back again.
Sometimes.
PostPosted: Mon May 15, 2023 7:08 am
Got it.
More custom than what I am used to.
Good luck getting it sorted out.
 Post subject: Congrats Stan!
PostPosted: Mon Jun 05, 2023 4:17 pm
Stan, I just saw a couple pictures of your car in the Aug. Mopar Action! Congratulations! :D :D
