It is currently Mon May 12, 2025 8:38 am
Post new topic  Reply to topic  [ 1132 posts ]  Go to page Previous 150 51 52 53 5476 Next
PostPosted: Sun Jan 14, 2024 11:26 am
Yeah, I worked the inside of mine until I could take a small propane torch and just keep making it warmer and warmer and it would go on with very little effort. Also put a little never seize on the shaft.
PostPosted: Sun Jan 14, 2024 12:14 pm
I used some anti-seeze, didn't seem to help.
I will post a picture.
PostPosted: Sun Jan 14, 2024 2:17 pm
Stan, Please forgive me I was having an old timers moment. I used the propane torch and never seize on my crank gear, not the Damper, to get it off and on easily. :?
PostPosted: Sun Jan 14, 2024 3:54 pm
You are forgiven! LOL
Here is the inside of the damper.
That is a small mountain of metal, hard, not loose metal.
The spot to the left is the first booger removed last time with a file.
PostPosted: Sun Jan 14, 2024 5:48 pm
Is that the damper with the Steel hub or the Aluminum hub?
PostPosted: Sun Jan 14, 2024 11:19 pm
Online
That's ugly.
PostPosted: Mon Jan 15, 2024 8:21 am
Steel ROMAC.
PostPosted: Mon Jan 15, 2024 8:22 am
That's ugly.
Agreed.
What are you using?
PostPosted: Mon Jan 15, 2024 10:08 am
Online
I have stock dampers on all my junk. I think I have accumulated 3 Fisher dampers, but never used any of them.
PostPosted: Mon Jan 15, 2024 4:21 pm
Steel ROMAC.
That is what I run too
PostPosted: Tue Jan 16, 2024 6:49 am
I have run 3-5 Romacs, all steel. Never did that...
PostPosted: Tue Jan 16, 2024 7:52 am
Yea oh course, it happens to me.
PostPosted: Tue Jan 16, 2024 11:39 am
What does the crank snout look like? Is it missing a chunk?
PostPosted: Tue Jan 16, 2024 12:56 pm
I have never seen a cam dowel break. that is crazy.
PostPosted: Tue Jan 16, 2024 1:21 pm
Bob Dally had one break on his Bonneville Barracuda 170. My guess is the bolt was not sufficiently tightened and/or loctited, at least in Bob's case. I always go 60-70 ft-lbs with mine and use loctite and have never seen this. One time I was out of loctite and I used JB Weld. I've heard of a couple more incidents like this, but it is rare.
Users browsing this forum: slantzilla and 2 guests
