It is currently Thu Jun 25, 2026 5:49 am
 Post subject: idustrial /6
PostPosted: Sat Aug 14, 2004 9:27 am
can a slant that was in farm equipment be used in a automobile. Friend has an old swather(farming) it has the slant & he is going to get rid of the unit.
PostPosted: Sat Aug 14, 2004 9:42 am
Car Model: '23 T-bucket
Vdart....I see no reason why you couldn't use the basic engine. Obviously, the mounts and most likely the accessory brackets will be different, but as far as I know, all the engines were externally identical, whether standard production or industrial.
You may need to do a cam change in order to broaden the power band, and the exhaust/intake manifolds might be different, but I really don't know that for sure.
Those did have a rotator on the top of the valve stem, between the stem and rocker arm tip, so keep an eye out for that when you do anything with the valve train.
Could you do me a little favor? I'm slowly building a database of everything that was built using the slant as a power source, so if you would, please supply me with the year, make, and model of this ag machine.
Thanks.....Roger
PostPosted: Sun Aug 15, 2004 5:46 am
Industrial Slant should also have a double roller timing chain in it. Carb and distributor may be different for a governor system. It also should have a Nitrided (surface hardened) crank.
One thing to watch for (just like the automotive Slants) would be the diameter of the register on the back of the crank. Pre-'68 motors are different than '68 and up. :shock:
PostPosted: Sun Aug 15, 2004 7:09 am
Some industrial slants also had low compression pistons. They are still flat tops, but have a lower compression distance.
 Post subject: Industrial Slant
PostPosted: Sun Aug 15, 2004 12:52 pm
thanks for the input, I'll try& get all the info pertaining to model/year of swather & if I can I'll shoot some pics.
