It is currently Thu Jul 09, 2026 12:11 pm
Post new topic  Reply to topic  [ 1217 posts ]  Go to page Previous 169 70 71 72 7382 Next
PostPosted: Sun Oct 06, 2024 6:34 pm
The tamer is to give you a controlled "slippage" correct? So it doesn't hit to hard?
PostPosted: Sun Oct 06, 2024 8:32 pm
Yes, on those brutal 2300 rpm launches.
PostPosted: Mon Oct 07, 2024 7:53 am
You’re out there runnin’ it instead of sittin’ at yer computer typin’ about why you ain’t runnin’ it.
That’s more than most of us can say. :wink:
You still plannin’ on Tulsa November 2nd…?
Askin’ fer a friend…
BTW: I wuz chattin’ with Jr the other day & he suggested you might could use sum help from one of them fast reckerd settin’ Slant 6 racer fellers…. I said I didn’t know any, but I’d keep my eyes open fer ya… :lol:
PostPosted: Mon Oct 07, 2024 10:49 am
Zilla, yes not broken yet.
Rick, if a smart person could get it adjusted it should provide a slipper clutch.
Zilla, thank you sir, can I have another.
Rob, yes still planning on Tulsa, and I too am looking for a smart slant guru.
Been thinking about what is the problem, besides the driver.
Pretty sure after Tulsa I will put my four barrel back on and test that.
November down here should allow some good test hits.
Some of you might know this but Jeff Kendall is having back problems.
I am sure he would like to hear well wishes from his slant family.
not2slow
PostPosted: Mon Oct 07, 2024 3:20 pm
I know a guy who knows that clutch thingy stuff. He might not be busy either.
Sorry to hear about Jeff. Hoping for a speedy recovery.
PostPosted: Mon Oct 07, 2024 4:54 pm
I sure hope when I put my 4 speed back in all I have to do is raise rpm to about 5000 and dump the clutch! :D Probably going to need those traction bars though!
That would be a great help I'm sure!
PostPosted: Tue Oct 08, 2024 11:29 am
Rick, your Valiant has suspension rise, that should make your combo work.
With my no travel, it's not easy.
Now that being said one of the smart fellows will tell me B.S.
PostPosted: Tue Oct 08, 2024 7:16 pm
With no suspension travel making it leave is pretty much witchcraft.
PostPosted: Thu Oct 10, 2024 2:44 pm
Finally got a video uploaded.
https://youtu.be/s5cIyZ2bba8
PostPosted: Thu Oct 10, 2024 4:13 pm
Is that a 4 link car?
PostPosted: Fri Oct 11, 2024 7:34 am
Ladder Bars.
PostPosted: Fri Oct 11, 2024 12:36 pm
Does it spin then go right? I can't see the video real good on my phone.
PostPosted: Fri Oct 11, 2024 1:11 pm
Zilla
I had a friend take the rear video, first time I had seen this angle in HD.
It seems to be spinning on this launch, maybe a few revolutions.
As it starts to move it goes a little right.
Not as much as before.
I have the tires up with different right and left pressures.
Maybe I turned the wheel a little on this pass.
It was going a lot more right on previous launches.
I was raising tire pressure for two reasons, get a little spin and then get the move to the right out.
I shifted at 6k, I can almost see that short shift from the tire patch going into second.
This video has a lot of information.
It looks better on a computer screen.
PostPosted: Fri Oct 11, 2024 2:31 pm
Have you plotted you IC and such?
I know I'm not telling you any secrets here, but until you get it to pitch rotate at the hit you're peeing into the wind. :oops: :oops: :oops:
It may be time for a 904 and footbraking it. :shock:
PostPosted: Fri Oct 11, 2024 6:11 pm
I could write a book about what is wrong with the suspension.
The ladder bars can not move the forward mount location up because the drive shaft will hit the last crossmember.
I am planning on replacing the rear shocks with some QA1 that will have a longer length, stroke.
That should give me more rear travel. More than the current 3/4 inch.
