It is currently Sat Nov 01, 2025 8:08 pm
PostPosted: Sun Oct 26, 2025 5:40 am
Hi Folks,
More free Slant 6 parts. Heavy stuff you need to arrange shipping or pick up. Light/small stuff I'll ship at your expense.
1) Core 170 Slant 6 crankshaft. Surface rust so needs turning. Small hub.
2) Core 225 Slant 6 crankshaft. Needs turning. Small hub.
3) 2800-3000 RPM high stall torque converter for 904. Tested and works great. Cracked pump drive hub so needs a new (alloy) one welded on by a professional.
4) Stock used 904 torque converters (at least 2).
5) Stock good used ignition coil.
6) Stock 70-up squareback alternator. Spins freely and I'm pretty sure it works since I kept it.
7) ~1965 stock valve cover with metal PCV fitting. Just needs cleaning up.
8) Stock cast iron alternator bracket (that bolts to head and block).
9) Stock 6.50-13 Goodyear spare tire on stock 13X4" rim. I think this has never been bolted on a car, and probably still has 1965 air in it... Excellent shape. Nice to hang on the wall?
10) Stock used brake pedal assembly from 64 Dart/Valiant. Good shape.
11) Stock 1968 1bbl iron intake. Nice condition with red paint, not much surface rust.
Let me know what you need/want. Thanks for the ad.
PostPosted: Sun Oct 26, 2025 9:19 am
Car Model: 1962 Dodge Lancer
Pm sent on tq converter
PostPosted: Thu Oct 30, 2025 6:03 am
Tell your friends, spread the word!
I'll start throwing things in the trash in a week or two.
First things to be junked will be:
1) intake manifold
2) stock torque converters
3) stock spare tire
4) brake pedal assembly
5) alternator bracket
Thanks!
PostPosted: Thu Oct 30, 2025 6:22 am
I will take the 170 crank if no one else is interested.
Can pick up on the next meeting, I think there are other parts in the pickup pile for me as well, possibly?
PostPosted: Thu Oct 30, 2025 10:33 am
Greg,
I'll set aside the 170 crank for ya. Can't remember what else? Oh, maybe a block or something big we talked about?
PostPosted: Thu Oct 30, 2025 3:39 pm
Greg,
Yes I thought there was a 2.93 chunk that you had set aside.
PostPosted: Fri Oct 31, 2025 7:56 am
Yep, that's it! 2.94 open, 741 case. All yours.
