It is currently Fri Feb 13, 2026 12:00 pm
PostPosted: Tue Feb 03, 2026 11:06 am
Hello, I am looking for trim clips for the roof trim on my '62 wagon.
I have yet to remove mine, I feel that If I do, many will break. I have a pattern to make new ones, but they will be 3d printed from some sort of resin, not steel/spring steel like the originals.
Clips for Part # 12 on the diagram above
PostPosted: Tue Feb 03, 2026 2:45 pm
Searching by part № probably dead-end. Pic of the clip will do more good.
PostPosted: Tue Feb 03, 2026 3:44 pm
Okay. I can get a mostly in tact one off a spare piece.
Hang tight.
PostPosted: Tue Feb 03, 2026 5:17 pm
I never found any for my Lancer,
Lucky I had a parts car to rob and get a set.
PostPosted: Wed Feb 04, 2026 6:26 am
Yep Stan has it. I will get'cha a big hi-res picture soon.
PostPosted: Wed Feb 04, 2026 7:20 am
HERE are some more fotos..
Enjoy!
PostPosted: Wed Feb 04, 2026 1:44 pm
Ooooohboy. That's gonna be a toughie. I checked the Gary Goers cattledog…nada. You might spend some time parked in front of AutoBodyClips.com, though I don't have high hopes.
PostPosted: Wed Feb 04, 2026 1:47 pm
That Is what I thought.
Thanks for thoughts. I may just try my hand at 3d printing them as well.
PostPosted: Fri Feb 06, 2026 4:35 am
Well Maybe I hafta just answer my own want ad this time.
Starting some development work..
I am sure it will take 36 redesigns to get it to fit after printing and testing.
Will try to print them in some sort of resin here at work. Will likely be a one-time use clip if made of plastic/nylon. Fingers will be sacrificed when removal is attempted.
Anyhoo, back to melting snow in the still. :D :D
PostPosted: Mon Feb 09, 2026 5:33 am
Car Model: 61 Valiant, 62 Lancer, 65 Val Ute, 66 Val convert
mmmm...
I might be able to help a little. Almost all the 60-62 wagon guys need these pieces. Let me check and get back to you. How soon would you need these. Sometimes I and quick but most times I operate at just under sloth speeds...
1961 V200 Black Valiant 3rd seat Wagon. 4BBL 170 Auto with a few special little bits here and there.
PostPosted: Mon Feb 09, 2026 6:50 am
mmmm...
I don't need them soon. I had a buddy 3D-print one yesterday, and it was sort of floppy on the Makerbot.
I wonder how they would be if they were printed in metal... Definitely some revisions to go through when turning sheetmetal into printed plastic.
