It is currently Sun Nov 29, 2026 2:34 am
 Post subject: Over center spring
PostPosted: Tue Nov 03, 2026 7:54 am
Car Model: 1971 Scamp
Howdy,
I need an over center spring for my 71 scamp 4 speed project.
 Post subject: Re: Over center spring
PostPosted: Tue Nov 03, 2026 11:07 am
Maybe use a diaphragm clutch and then you won't want/need the overcenter spring??
PostPosted: Tue Nov 03, 2026 11:16 am
Nobody makes one that fits the stock flywheel.
PostPosted: Tue Nov 03, 2026 3:29 pm
You can try a skookum fiero part.
They likely are likley the same bolt pattern from my research
Holding power? Not sure on that unless you get one from spec etc.
I have one on my heavy duster and it has been fine.
I bet the springs for the pedal is the same as other mopars.
PostPosted: Tue Nov 03, 2026 4:11 pm
Any year fiero? 6 cyl or 4 cyl make a difference?
PostPosted: Tue Nov 03, 2026 5:38 pm
I don't think the Fiero is a mopar 6 cylinder pattern is it ???
Wasn't it Ram that you guys just got to do some Slant 6 stuff a couple years ago? I thought they were now making bolt in Slant 6 pressure plates?
Here it is. https://ramclutches.com/product-categor ... engine=225
PostPosted: Tue Nov 03, 2026 6:03 pm
It’s a gm bolt pattern and you must use their $300 flywheel
PostPosted: Wed Nov 04, 2026 3:53 am
I guess I was wrong on all accounts. Sorry. So they only made the dual disc setup for the stock 122 T flywheel then??
I went back and looked at the link I posted and I don't see anything about the GM pattern at all. I put in 1970 dodge passenger car, Slant 6 , and those 3 came up.
PostPosted: Wed Nov 04, 2026 4:46 am
Wouldn't the 80s trucks take the same clutch? As long as we're talking about the 833OD and not the granny gear trans it has the same 122 tooth flywheel. I know that Luk makes a diaphragm clutch for that. I have one.
PostPosted: Wed Nov 04, 2026 5:32 am
Got a link or part number?
PostPosted: Wed Nov 04, 2026 5:34 am
Did you read the description?
9.5 X 1-23 spline Chrysler
Diaphragm replacement for use with RAM flywheels
6 spring hub organic facings
For applications up to 350 hp
Includes pressure plate, clutch disc, release bearing, alignment tool
PostPosted: Wed Nov 04, 2026 9:20 am
I read it twice and it still didn't click! :D :D I thought the whole thing with them was finally a pressure plate you cold bolt onto the stock flywheel that wasn't total junk. As I said above I guess I was wrong. I would say they shot themselves in the foot on that one. Glad you can get the flywheel and everything, but most people wanting a decent clutch for a driver don't want to drop and extra $3-400 for a flywheel. Racers will happily get the premium setup from them.
PostPosted: Wed Nov 04, 2026 9:25 am
Yeah I’ve been chasing my tail on the diaphragm clutch. It’s almost $800 for their clutch and flywheel package after tax/shipping. I’m not racing or even hot rodding. I just need a stock clutch.
PostPosted: Wed Nov 04, 2026 9:56 am
I do think I remember LUK making a "stock" diaphragm setup. I don't know anything about them though.
PostPosted: Wed Nov 04, 2026 9:57 am
Not available anywhere that I can find.
