It is currently Wed Jul 15, 2026 11:39 pm
PostPosted: Sat Nov 06, 2004 2:45 pm
Car Model: 71 Dodge D100 64 Plymouth Valiant Wagon
I've been having the same problem as a lot of you with burning out exhaust manifold to header pipe gaskets.
Since I went from the stock exhaust to two and a quarter with the super six, it's entirely possible that the guys at the muffler shop didn't get the flange welded at the correct angle.
And since that shop has closed down now, and since I don't want to spend any more $, I cut the header pipe, and took about a half inch off the end after cutting it. Then I bolted down the flange for the twentieth time, lots of the red goop and stage 8 fasteners. Then I used a six inch piece of flexible exhaust pipe to hook the pipes back together. There's not much space between the two pipes, I just used a lot of flexible pipe because I figured overlap wouldn't hurt. I've got it clamped down at both ends and so far so good.
Hopefully the flexible pipe will flex before strain is put on the flange-to-exhaust connection.
Keepin my fingers crossed,
Joe
Joe Hoppe
71 D100 225 Super Six 727 AT on 2008 Crown Vic CopCar frame
64 Valiant Wagon 225 904 AT 3:23 8.75"
