It is currently Sun Nov 29, 2026 7:00 pm
 Post subject: picture quality loss
PostPosted: Thu Dec 02, 2004 9:34 am
health as an outcome, we must also be happy about it. Step Three: Pierre?s Plan of Action recently reported that rocket-fuel chemicals were found in mothers'
tion. One of these isgeographic isolation, braries provide a rich source of diverse and the premium-priced basmati rice. Similar
chromosome after a specific promoter. As cofactors are involved with cycles involving Hsp70 homologs. of the growth factor/cytokine receptor
No, it's some jackasses with obvious mental problems having their pictures taken while out in public Since they're the only thing on the website, it gives the impression that these people are some k
KenG
PostPosted: Thu Dec 02, 2004 9:37 am
Use some High-temp RTV copper. I used it when I still had mine and worked fine. You should still have some when you put the two manifolds together, right? :wink:
PostPosted: Thu Dec 02, 2004 11:22 am
Eric, I tried copper RTV.- it just gets blown out. When I assembled the manifolds, the new shim seals fine since I squared the mating surfaces.
Napa has the right material, at $70 per sheet. I dont think so. Wonder what else will work
KG
PostPosted: Thu Dec 02, 2004 12:23 pm
I've run into this problem as well. One solution is to buy a cheapo set of small-block shivvy header gaskets (the white Mr. Gasket ones) and cut the well gasket out of the extra material between the ports. The kicker is, the header gaskets are still usable for a crummy SBC, so you can give 'em to one of your shivvy buds when you are thru... :roll:
I have also gotten some of the high-heat sandwich type gasket material from "Auto-zone" for about 10 bucks for a sheet (think it was about 12" x 24"). I don't know if any of the other Idiot Auto chains carry it... Only problem with the good stuff is that it's a pain to cut thru the steel layer - patience and a good utility knife helps. Matter of fact, if you send me $10, I'll cut you a gasket from my sheet and mail it to you! :wink: :)
D/W
If it ain't broke, fix it!
PostPosted: Fri Dec 03, 2004 12:21 pm
NAPA and Autozone here locally provide Gaskets. I just bought one for my /
Cost ~13 bucks. Is there some reason not to use this gasket?
When in doubt, empty the magazine.
'72 Dart Swinger /6 - My Yard Dart!
'01 Ranger P/U 4x4 X-cab
We buy and sell MOPARTS & Ford Parts!!!
http://www.usironauto.com
PostPosted: Fri Dec 03, 2004 1:45 pm
72swing-
What brand or PN? Nappy and Schmucks have both come up empty
 Post subject: Autozone - Felpro
PostPosted: Fri Dec 03, 2004 2:06 pm
Autozone.com shows intake/exhaust gasket for /6 P/N: MS9610B-1 for $11.99
Link I found was: http://www.autozone.com Just enter your car year and do a search for : Exhaust manifold gasket. :D
PostPosted: Fri Dec 03, 2004 2:14 pm
The gasket being referred to here is the gasket for the chokewell (yes?) which is specific to '70-'72 slant sixes only. If there is a known commonly available one, it would be news to me. (good news, though) I haven't seen one come in an intake/exhaust gasket set in a long time.
D/W
PostPosted: Fri Dec 03, 2004 2:26 pm
That gasket is this:
Looks like I'll be making one, unless the Mopar still makes em. Thanks for the input!!!
PostPosted: Fri Dec 03, 2004 3:41 pm
THAT'S not a chokewell gasket! :shock: :roll:
(am I missing something?)
THAT gasket comes in the intake/exhaust manifold gasket set. Some here probably even have spares lying around!
D/W
PostPosted: Fri Dec 03, 2004 4:25 pm
The picture of the metal shim gasket KenG posted deffinately does come in the engine gasket sets.
I believe kragen etc. can get the choke cup thermostat gaskets but they are paper and burn out easily. When I was still running a stock manifold/carb/choke, I found the only thing that worked were the original asbestos gaskets. I bought all of them up that showed up on the dealer locator.
So napa sells asbestos based gasket sheets? Isn't that a federal no-no ?
PostPosted: Fri Dec 03, 2004 4:36 pm
Sorry, I get a little vague when typing. The Fel-Pro MS9610-B1 is the shim I posted a pic of. Apparently the chokewell gasket isn't made anymore. The material Napa can get isn't asbestos, but is a sandwich style material with a temp resistance of 1300 degrees. However I will not pay the $70 asking price.
Looks like a header gasket is going to get sacrificed
btw, did you know Dorman makes exhaust manifolds for the /6?? Theres more poly 318 stuff in the boneyards here than /6, so this may be our only choice before too long. Although at $300 I think I'll be using it as last resort
PostPosted: Fri Dec 03, 2004 4:57 pm
Probably a dumb question, but someone please enlighten me:
Why does the chokewell need a gasket? The pocket is isolated from the exhuast (I.E. the pocket is not open to the exhaust runner--unless the 70-72 specific is different?), so it needs only to heat up the thermostatic coil for the choke pulloff---why does there need to be a gasket? Sitting right on top of cast iron heat 'loss' should not be an issue, and if the pocket is not open to the exhaust runner there is no exhaust leak.....what am I missing???
From the comment above about the Copper RTV getting blown out--it sounds like the pocket IS open to the exhaust runner...which is something I have not seen (not to say it doesn't exist). Is this the case?
-S/6
PostPosted: Fri Dec 03, 2004 6:07 pm
http://www.yearone.com/serverfiles/head ... A14AA55841
Here ya go....I think..... :?
PostPosted: Fri Dec 03, 2004 7:13 pm
Super6
i finally got it myself this kind had the choke suspended in the exhaust passage. So if you remove the choke coil and the shield under it you can stick you finger in a exhaust passage.
