It is currently Sun Nov 29, 2026 1:10 am
PostPosted: Sun Dec 05, 2004 10:02 pm
Going to dual out my '73 this week and have a question.
I'm running a 6 into 2 Clifford header now, I was told (at a MOPAR car show) that for my mostly stock engine I should run 1 7/8ths I.D. pipes for duals, 2 1/8th for a single exhaust. I did a search about this here, and came up with about 1000 posts, but after going thru many of them, still didn't find a recommendation.
Any recommendations, preferences or experiences?
I ain't buying the $100 Flowmaster mufflers, so save your fingers on that!
Thanks
'73 Dodge Dart Swinger, /6, Clifford intake, Holley 390 cfm 4-bbl, clifford headers, dual exhaust
PostPosted: Sun Dec 05, 2004 10:17 pm
Ya get what you pay fer. $15 cherry bombs sound like $15 dollar cherry bombs. I plan on running a single 2.5 into a cat (because i have to) then into a flowmaster 40 2 chamber or mabey a 50 2 chamber. But i also plan on having a dump before the front door .
PostPosted: Sun Dec 05, 2004 10:19 pm
I run the same headers with a single 2 1/4" single exhaust into a dynomax superturbo muffler. The Y joins at about the transmission, and goes directly back from there.
Sound is a bit louder then stock, but not rumbly or anything, mild mannerd.
PostPosted: Sun Dec 05, 2004 11:27 pm
Ha! 8)
No, I wasn't going for the $15 Cherry bombs or any other glass-pack. I'm one of those weird people that don't like the sound of Flowmasters.
Maybe the guy told me that 2 1/4" was the size for the single.
PostPosted: Sun Dec 05, 2004 11:41 pm
Hi,
Well, it's not on a slant, but I run a dual 2" system on my 265 hemi.
We were lucky here in Australia, the last few thousand 265's came out with dual outlet exhaust manifolds.
I was also lucky enough to pick up that twin 2" system cheap second hand...the guy who made it was a fitter and turner, and all the elbows are mandrel bent, and welded. The welds are just beautiful!
Anyway, twin 2" sounds really nice with good mufflers, mine sounds like an older european sports car, maybe a 4.2 Jaguar of some sort. Has a nice deep burble at idle, which turns to a bit of a snarl at higher rpms...but I don't run a crossover pipe so I get that sound.
Regards, Andrew.
PostPosted: Mon Dec 06, 2004 6:36 am
I ran the Clifford 6 into 2 system on my 65 Dart for quite awhile with 2 in pipes into a Super Turbo muffler from one of the local parts stores. At the rear it sounded like a V8 at idle. When I would get on it, the sound totally changed.
 Post subject: Exhaust Size
PostPosted: Mon Dec 06, 2004 7:13 am
The Chrysler racing manual recommends 2½" pipes to connect to headers. Tony Lewis of Seven-L Engineering wrote up a performance guide in 1982 and recommended a 3" single exhaust. A 3" single exhaust has a flow area of 7.07 in² and a dual 2-1/8" pipes are very close to that (3.55 in² each). A 2¼" pipe has a flow area of 3.98 in² while a 2½" pipe has 4.91 in². The flow area becomes much more important as you run at higher RPMs because the airflow is directly proportional to engine speed. That means, if you don't rev your engine high, you don't need really big pipes.
While increasing the diameter of your exhaust pipes will improve your performance, as with everything else, the results are subject to the laws of diminshing returns. Once you have a low restriction exhaust, it becomes harder and harder to make it lesser restrictive. There isn't an optimum exhaust pipe size for maximizing power, just larger is better. The problem then becomes fabricating the pipes underneath your car. Larger pipes are harder to bend so you might end up with flattened pipes as they are bent to clear the axle.
I don't recommend that you install larger that 2½" pipes and 2¼" would be the largest I would go. I think 2" would be plenty big (even for a single exhaust) and would make fabrication cheaper and better looking. I'd also recommend going with an all stainless steel system (T304 preferably over T409) if you are planning to keep your car for any length of time.
Frank
PostPosted: Mon Dec 06, 2004 7:24 am
I run 1 7/8 straigt from the head, then it goes to dual 2" tailpipes. Custom fabrication since we don't have much slant stuff here in argentina. The sound is supernice, it has 2 free flow mufflers (nor turbo mufflers) and sound at idle is like a V8, then it goes a li'l bit louder around 55 mph (say 2,2 k rpm) and after 2500 rpm id quiets down to a nice jag like sound.
Juan Ignacio Caino
 Post subject: Re: Exhaust Size
PostPosted: Mon Dec 06, 2004 7:53 pm
Thanks Frank and everyone else. I will go with the 1 7/8th" or 2" pipes. I don't plan anymore engine mods. The system will be custom-made, so maybe the fabricator will have some input. Dropping it off Wed or Thurs.
I would love a sound like the Jag 6's, but don't want it too loud.
PostPosted: Tue Dec 07, 2004 12:52 pm
Hi,
I actually recently spoke to the folks at Clifford, and they said that for Clifford 6X2s - you don't want to go more than 2 inch pipes - he didn't make a distinction between single or duals (which I thought was interesting).
He said 2 inch, to a 2 1/4 muffler, and then back to 2 inch for 18 inches out the back of the car would give the best mix of torque and HP.
I've got flowmasters (40s) on mine - the sound is like a V-8 at idle, and then kind of scary and metallic at cruising speed. I like it, but it's not quiet.
k
1963 Dodge Dart, motor by Doug Dutra, Offenhauser two carb intake, Pertronix, Clifford 6x2, Flowmaster 40's, Erson RV15/295 RDP, head work. Addco anti-sway bar, urethane suspension bushings, KYB's, racing leafs, SSBC discs. Need ZDDP? Get STP.
PostPosted: Tue Dec 07, 2004 1:02 pm
I love them flaomaster 40's they sound great on my 318 dakota. Can't wait till after christmass so i can stick one on the slant. Wide open and it gives you chills
PostPosted: Thu Dec 09, 2004 8:27 pm
Got the car back today - NOTHING sounds as sweet as a straight six with pipes! Used 2" pipes all the way back, Walker "Turbo" mufflers.
Interestingly, as a couple of you mentioned, it DOES sound like a V-8 rumble at idle, but changes at speed.
Got some horsepower back, too. Been too long with the headers and a small single exhaust pipe with a stock muffler.
PostPosted: Thu Dec 09, 2004 8:34 pm
I love my slant sixes, but I heartily disagree with THAT statement! :lol:
My Duster sounds a lot like a fire truck. I do like the open header sound on a six, though. Different, sounds kinda like an airplane :)
D/W
If it ain't broke, fix it!
PostPosted: Thu Dec 09, 2004 8:49 pm
All in the ear of the beholder, I reckon! 8)
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 6 guests
