It is currently Sat Nov 28, 2026 4:17 am
PostPosted: Sun Dec 12, 2004 2:52 pm
I have a 66 valiant 4 door with the super 225 (1 bbl) It needs new bearings, and an oil pump. under the oil pan, the k frame, and the steering linkage are in the way hard core. It doesnt look like I can lift the engine any without the trans hitting the firewall. Am I going to have to totally remove this engine to do this?
Thanx
PostPosted: Sun Dec 12, 2004 4:34 pm
SSRN National Champion
How do you know you need new bearings. Low oil preasure?
The oil pump is not in the pan on a slant engine. It is a external oil pump mounted on the passenger side of the block where the oil filter is above the oil pan.
If the car needs bearings the engine needs to come out and rebuilt.
Thanks Ron Parker
Building A Better Bagel Burner.
PostPosted: Sun Dec 12, 2004 4:35 pm
Okay neighbor, if you have to change the oil pump and bearings for ANY reason, it would seem to me worth the effort to yank the 'ole bullet and give it a COMPLETE going over. Besides, the aggrivation and extra effort to screw with the bottom end while it's still in the car is worse than just unscrewing everthing and sitting your slanter on a stand. If time, space and tools are a problem, heck, let me get through the holidays and then truck it up to my shop in Saginaw, I'll help ya. There's a crackerjack Mopar club in Fort Worth that is chock full of sharp folks, better than any library, if we get stuck with a technical question. No BS here, try www.cowtownmopars.com for more help and info. RICK 8)
If you can't be good, at least be colorful
PostPosted: Sun Dec 12, 2004 4:37 pm
I didnt know the pump was on the outside, I just havent looked at this particular engine that close yet. However I am a very experienced mechanic. 10 years, owned 300 vehicles, worked on them all, I now buy and sell cars for a living. I buy them broke, I sell them fixed. This one I know can be saved by a set of bearings and a pump, for sure.
PostPosted: Sun Dec 12, 2004 4:40 pm
I wish I had the money for that. I work on a duct tape budjet, know what I mean? After doing it for years I've gotten very good at it. (not actually using duct tape I promise.) I looked at it again tonight and yeah I probably am going to have to remove the engine. I also thought of loosening the trans mount and scooting the whole thing up and forward.
PostPosted: Sun Dec 12, 2004 4:43 pm
The pump change is tough did one on a 76 dart Miss Daisy and it took two of us all day with the engine in the car. Clearance was the issue. Chiltons say it is a four hour job but on the 76 no way. Thanks Ron Parker
PostPosted: Sun Dec 12, 2004 4:47 pm
hmm figures. Basically what Im doing is seeing if this car will sell on ebay... if it doesnt I will probably be driving it. If you'd like to see it, go here
<br>
http://cgi.ebay.com/ebaymotors/ws/eBayI ... eName=WDVW
PostPosted: Sun Dec 12, 2004 5:08 pm
btw just so ya know I am one of the few people who wished he could keep every car ive ever owned..... lol
PostPosted: Mon Dec 13, 2004 8:32 am
It's not a fun job, but it can be done. I'm familiar with shoestring budgets and not wanting to disturb things that are still working fine by yanking a motor. I had a rod problem with Kermit ('72 Valiant) several years ago (see related posts from long ago) and did a bearing job and oil pump with motor in-car (not the first time I've worked a /6 bottom end still resident in car). It took a couple or three afternoons taking my time and going slowly and methodically.
Basically you have to unfasten the motor mounts (just the driver's side unless you're gonna do the pump) and jack up the motor (fan shroud removed!) just enough to get the pan out. You will also have to drop the centerlink down out of the way. Easiest way I have found to do this is remove the idler arm where it fastens to the K-frame and pull the pitman arm from the steering box. Pull the backs of the wheels together, and with a few rags, you can even use the centerlink as a headrest! :) Oh, yeah, once the pan is loose, turn the crank so that the weights are up in the block at the front, else you will be cursing and the car will not give up the pan.
D/W
If it ain't broke, fix it!
 Post subject: useful info
PostPosted: Mon Dec 13, 2004 8:43 am
thanx dude, finally some useful info. What if I do want to do the pump? does it have a spring to regulate pressure like chevy? Can I somehow inspect it? Thanx again.
PostPosted: Mon Dec 13, 2004 10:16 am
The SL6 oil pump has a releaf valve and spring.
You can get to it from under the car, look for the plug with the square head, it faces the front of the car.
To remove the oil pump from the car you need to undo the right side engine mount and jack up the engine, way high, to get the pump post to clear the block.
PostPosted: Mon Dec 13, 2004 12:42 pm
thanx again! nice pic and info... saved me some time.
Users browsing this forum: Ahrefs [Bot], DuckDuckGo [Bot], Google [Bot] and 6 guests
