It is currently Tue Jul 14, 2026 10:36 pm
 Post subject: Floppy side mirror fix?
PostPosted: Thu Dec 16, 2004 9:13 am
Car Model: 1962 Lancer 770
Next on the problem list: my mirror!
I have a nice driver's side mirror on my 62 Lancer that has too much play in it. it basically flops down and is useless. I was told that its possible to try and use a small punch to put a indentation in the ball of the mirror that would hold it in place? Or do you pinch the housing down on the ball?
Anyone have any suggestions as to a fix? I'd hate to replace the otherwise very very nice mirror.
I have some pictures of it here:
My flopppy mirror
Thanks again
 Post subject: MIRROR repair
PostPosted: Thu Dec 16, 2004 7:01 pm
take the glass out of the front, it should have a thin metal ring that holds it in place, once this is out you will see the pivot area, you might get lucky & just tighten up the screws holding the pivot, otherwise that would be the area you dimple/punch to take the slop out. Enjoy your ride!!!!!!
PostPosted: Thu Dec 16, 2004 7:51 pm
i'll give it a try and see what I can do! thanks!
