It is currently Fri Nov 27, 2026 6:56 pm
PostPosted: Sat Dec 18, 2004 12:19 pm
when I turn the key to the "start" position the engine starts/runs as soon as i let go of the key "on" position the engine cut out/dies.
if i hold the key to the crank/start it stay running.????
this is on a fresh rebuld with the lean burn system removed.
and orange box ECU and 1997 rebuilt DIST.
my brain hurts from all this trouble shooting :|
thanks in advance :wink:
PostPosted: Sat Dec 18, 2004 12:50 pm
The problem is your ballast resistor.
Bob D
PostPosted: Sat Dec 18, 2004 2:12 pm
Bob D
thats what i was thinking so,,,,i used the coil from the lean burn and by-passed the ballast and ran a jumper wire to the + side of the coil.
no change!!???
Paul
PostPosted: Sat Dec 18, 2004 2:13 pm
btw the 1979 dist. not 97 but,,,you knew that
PostPosted: Sat Dec 18, 2004 2:14 pm
Bob D
thats what i was thinking so,,,,i used the coil from the lean burn and by-passed the ballast and ran a jumper wire from the + of the battery to the + side of the coil.
no change!!???
Paul
Users browsing this forum: Google [Bot] and 7 guests
