It is currently Sat Nov 21, 2026 5:10 am
 Post subject: Push-start question 727
PostPosted: Tue Mar 01, 2005 9:19 pm
I have a 63 with the pushbutton 727 transmission.
The Drivers Manual says you can push start it.
I rolled down a hill in second and the motor started at about 27 mph.
Is it OK to do this or is it harmful?
PostPosted: Tue Mar 01, 2005 9:33 pm
It's not in any way harmful to my knowledge. The rear pump in pre-66 727's (wheel/driveshaft driven) allows the trans be pressurized and operational with the motor "off", so putting it in drive spins up the crankshaft.
D/W
If it ain't broke, fix it!
PostPosted: Wed Mar 02, 2005 4:34 am
Doesn't hurt it at all, they were designed to do that. That was a nice thing about many auto transmissions, back in the 50's and 60's. The torqueflite trans lost this feature after 1965, when the rear pump was removed.
