It is currently Sat Oct 26, 2024 4:24 am
PostPosted: Thu Mar 31, 2005 10:09 am
I just got my oil gauge rigged and I don't know what numbers are dangerous. I specifically need to know the average and lowest tolerable pressures at full warm on a low idle. Thanks in adavance
PostPosted: Thu Mar 31, 2005 10:13 am
My 225 slant reads 50 steady.
PostPosted: Thu Mar 31, 2005 10:51 am
IMO, lowest tolerable at hot idle: 5 psi
General rule of thumb, you want 10 psi oil pressure for every 1000 rpm; 10 psi for 1000 rpm, 20 psi for 2000 rpm, etc.
My slant runs about 35 psi oil pressure at hot idle, 52 psi everywhere off-idle--that is on a fresh rebuild with approx 1500 miles though.
-S/6
PostPosted: Thu Mar 31, 2005 10:53 am
Mine is 50psi at idle, cold. Goes down to 25psi warmed up. Is 50psi at all driving speeds warmed up.
Users browsing this forum: Semrush [Bot] and 3 guests
