It is currently Sat Nov 21, 2026 2:16 pm
PostPosted: Mon Apr 04, 2005 10:05 pm
I was wondering since all the shock plates for sale, they usually say 8.75" or 9.25", do they fit the 8.25" too?
Are the U bolts for springs(3" by 7" long) and axle housing the same too?
The backing plates for an 8.75" rear, does the SBP and LBP use the same plate? thanks.....Jerry
73 Dart 4dr
70 duster
75 VW bug
ex-88 honda rice rocket
ex-70 cuda 383
PostPosted: Tue Apr 05, 2005 2:30 am
there are no LBP 8&3/4" rears.
PostPosted: Tue Apr 05, 2005 4:50 am
I'm sorry, but that is not correct. There are no "A" body LBP 8 3/4 rears, they are all small bolt pattern (4 inch), but all other 8 3/4 rears are large (4 1/2) bolt pattern
PostPosted: Tue Apr 05, 2005 5:40 am
8 1/4 and 8 3/4 rears both use the same shock plates and U-bolts. they haved the same spring perches and 3" axle tubes. 10" brakes all use the same backing plates and wheel cylinders. IIRC even 7 1/4 10 " brakes use the same backing plates because the later 7 1/4's flair out the end of the tubes.
PostPosted: Tue Apr 05, 2005 9:31 am
I could be wrong, but I think the 10 x 1 3/4 brakes use a different backing plate then the 10 1/2 brakes. I have two rears with 10 brakes sitting on the ground. One with 1 3/4 and one with 2 1/2, and the offset from the mounting flange looks different. Don't have time to take the drums off, to measure.
PostPosted: Tue Apr 05, 2005 10:37 am
Oh that's right, I missed that. Sorry...
PostPosted: Tue Apr 05, 2005 12:52 pm
I think you got me there Charlie. I know I put 7 1/4 brakes on an 8 1/4 and they worked great. It would make sense to me that 3/4" wider drums would need a deeper offset to the backing plate
 Post subject: 8.25" - 8.75" rear
PostPosted: Wed Apr 06, 2005 3:25 am
Thanks everyone...got my answer...
was at a swap meet and there were some shock plates real cheap for 8.75", guy said it was only for 8.75" and 9.25" and not 8.25"...my loss, since I didn't buy them....Jerry
73 Dart 4dr
70 duster
75 VW bug
ex-70 cuda 383
Users browsing this forum: Amazon [Bot] and 3 guests
