It is currently Thu Jun 11, 2026 6:28 pm
 Post subject: Broken Carb.
PostPosted: Mon Apr 11, 2005 8:30 pm
Just re-did my manifold gaskets (No broken bolts or studs- Thank goodness), but when it came time to re-install the carb, I managed to over-torque the mounting nuts and cracked the base-plate(D'oh!). My question is this; is it possible to have the carb welded (it's a Holley 1920 in pretty good shape- other than being in two pieces!)? Or am I insane for even thinking of it? I'd buy a re-build, but I know this one works (worked) and financial constraints make it a bit dicey. Help Please!
1970 four-door Dart, 225/A-904/2.45 gears. 0-60 in twenty three minutes!
PostPosted: Mon Apr 11, 2005 8:41 pm
I don't think you'll have much luck with a repair. My advice would be to get a used carb to salvage parts from.
 Post subject: Hoo man.........
PostPosted: Mon Apr 11, 2005 8:52 pm
Better get a new carb, I really don´t think it can be welded, even repared.
Mopar Muscle is well defend by Slant Six!
Valiant Duster 1971
PostPosted: Mon Apr 11, 2005 9:52 pm
That's just as I feared. While I'm at it, I was thinking of replacing the automatic choke with a manual set-up. Any advice?
PostPosted: Tue Apr 12, 2005 6:37 am
Get a good plastic sleeved cable at NAPA.
D/W
If it ain't broke, fix it!
