It is currently Thu Nov 19, 2026 8:53 pm
 Post subject: gas gauge
PostPosted: Sat Apr 23, 2005 11:27 pm
own a 69 dart gas gauge stop working, anyone ever have this happen, and how do i check this out?
PostPosted: Sun Apr 24, 2005 6:57 am
Still with the problem, still working on it, sometimes my gauge starts working, but not good.
Mopar Muscle is well defend by Slant Six!
Valiant Duster 1971
PostPosted: Sun Apr 24, 2005 9:47 am
Check the contacts of the wires coming from the gas tank. They might be oxidized. Just guessing...
Mopari on parasta mitä rahalla saa - Mopar is best you get with money
PostPosted: Sun Apr 24, 2005 4:18 pm
Already check anything from gas tank to gauge, I took to repair my gas gauge, but only worked well some days.
Valiant Duster 1971
PostPosted: Sun Apr 24, 2005 5:40 pm
yep check the connecton at the tank and the groundind strap,if that doesnt work check the back of the cluster mine had some corrosion cleaned it up with a scotch brite pad and tightened up the nuts on the gauge and mine was up and running again
 Post subject: gas gauge,
PostPosted: Mon Apr 25, 2005 7:03 am
checked the wire at the tank, grounded it , gas gauge went to full, did i ground the gauge to long, shows no movement when i tryed the ground trick again, if so how do you removed the gauge from the dash, i'm wounding if i screwed up both the gauge and the sending unit in the tank, any HELP!
PostPosted: Mon Apr 25, 2005 12:36 pm
Well, looks like time and recent water leak finished with my gas gauge, so I buyed a new one, not original, I needed to put it below dash, anyone got a clock for dash? they use the same space in dash.
Valiant Duster 1971
 Post subject: Re: gas gauge,
PostPosted: Mon Apr 25, 2005 3:38 pm
Grounding the wire at the tank shouldn't damage the guage, since its almost fully grounded when the sender is indicating a full tank anyway.
You may still have a wiring problem and moving the wire only temporarily made it work.
Tests to do:
1) measure the resistance of the sending unit with an ohmmeter
2) measure the voltage at the sending unit wire with the ignition switch on (should flip flop between 0 and 12 volts if you have a stock instrument cluster regulator)
3) Does your temperature guage work? If not, it may be the instrument cluster regulator that's bad.
PostPosted: Mon Apr 25, 2005 4:49 pm
Checked your fuses lately?
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Mon Apr 25, 2005 7:17 pm
thanks for the responds, temp gauge DOES work,i'll go over the test again, took the kick panel off, unpluged the plug, grounded the blue wire with a test light, but no needle movement, i just want to be sure one way or the other that the dash gas gauge is no good before trying to remove the instrument cluster
 Post subject: con't
PostPosted: Mon Apr 25, 2005 7:18 pm
oh yea! is there a fuse i don't know about somewhere
