It is currently Tue Jun 23, 2026 5:32 am
PostPosted: Fri May 20, 2005 5:42 pm
Where is the circuit breaker for the headlights located on a 74 Duster.
Run my headlights for about an hour and they will shut off and a second later come right back on. Nothing else goes out, just the headlights. I think it could be the circuit breaker.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Fri May 20, 2005 6:06 pm
The thermal cutout circuit breaker is built into the headlamp switch.
A new headlamp switch will probably fix the blinkout symptom, but to fix the root problem and get much brighter headlamp light, put in relays.
PostPosted: Fri May 20, 2005 7:30 pm
I just replaced the headlamp switch. Will look into the relays though. Is this problem common on old Chryslers or is my wiring about shot?
82 D150-225/727
PostPosted: Fri May 20, 2005 7:40 pm
A lot of cars, old and new, have serious voltage drop in their headlamp circuits.
 Post subject: Headlight relay
PostPosted: Fri May 20, 2005 8:40 pm
Here is some info. I have converted one of my Studebakers to dual realys, it has poorly designed switch to begin with, age don't help. Big difference.
http://www.madelectrical.com/electrical-tech.shtml
http://danielsternlighting.com/home.html
Ross Rither
1964 Dart, 170
225, super six.
PostPosted: Fri May 20, 2005 9:24 pm
I'm not saying this 'cause the second link rrither posted is my own site, but to provide warning: The madelectrical site's headlamp relay method is halfåssed, and there are accuracy problems with most of the other articles on their site.
PostPosted: Tue May 24, 2005 6:45 pm
Dan, I just had a brainstorm. The previous owner put a set of Halogen headlamps on in place of the sealed beams. Do Halogens pull more than sealed beams? If so, I think that might be what is causing my circuit breaker to trip. I have a new set of sealed beams ready to put on the car.
82 D150-225/727
PostPosted: Tue May 24, 2005 8:24 pm
No, the halogen sealed beams, the regular sealed beams and the replaceable bulb H4 type units all use within a couple watts of one another. Essentially the same (the exception being replaceable-bulb headlights with overwattage bulbs, that is, higher than 60/55).
The switch breakers DO get soft with age, and the wiring resistance DOES increase with age. Don't downgrade the headlights to mask the symptom -- fix the problem!
PostPosted: Tue May 24, 2005 9:14 pm
I just changed my headlight switch about a month ago because of the same problem. Is the best thing for me to do is runn some new lines from the switch to the lamps.
82 D150-225/727
PostPosted: Tue May 24, 2005 9:21 pm
No, the best thing for you to do is to leave the factory wires alone and install relays.
