It is currently Tue Sep 22, 2026 3:15 am
PostPosted: Mon Jul 18, 2005 9:08 pm
I put an Offenhauser intake and the four bbl Holley 390 on my 1965 Valiant.
I also changed the cylinder head to one I pulled of a 1976 dart.
I don't have the carb or the valves adjusted that well yet but, it is running.
However, it is running a bit hot.
Do you think that this might be because I set the valves a bit "loose"? I set them at more than .022 exhaust and over .012 intake because the car was cold when I was doing this and I figured that the heat would cause it to tighten up?
Or do you think that running different spark plugs would help?
Thanks
 Post subject: Lean runs hot
PostPosted: Tue Jul 19, 2005 8:18 am
A lean fuel mix will run hot. It's just my first guess, but check for vacuum leaks and mixture adjustment.
I won't say your other ideas are way off, but I don't really know.
1980 Aspen 225 super six
PostPosted: Tue Jul 19, 2005 4:57 pm
do yourself a favor and readjust the valves hot. cold adjustments just aren't accurate.
 Post subject: running hot
PostPosted: Wed Jul 20, 2005 8:01 am
check ignition timing and your vacuum advance. the vacuum advance hose fell off my dist. one time and caused the engine to overheat(read: boiling) from retarded timing.
zedpapa
soon to have 5 gears!!!
PostPosted: Wed Jul 20, 2005 9:45 pm
I would say warped cylinder head and/or bad head gasket.
Users browsing this forum: Amazon [Bot] and 9 guests
