It is currently Fri Jun 19, 2026 7:01 am
 Post subject: Voltage Limiter Question
PostPosted: Thu Jul 28, 2005 9:47 am
I finally recieved my new gas tank after a three week wait. (it seemed like 3 months) I put in the new sender and made sure that the ground was perfect (or as near as possible).
NOw it seems that I have the old temp and fuel gauge no workie problem. I think that I have read enough in these boards to know that it may most likely be that little half a volt limiter up behind the dash cluster. Is this a part that can be bought new or will I need to go to the salvage yard and hope for the best?
Chas///
Well off to DVM to finalize ownership!
(Oh by the way it's a 1975 dart swinger 2 dr HT slant six)
PostPosted: Thu Jul 28, 2005 11:29 am
IT's actually a 5-volt voltage limiter. You can get a replacement from NAPA, Echlin number IR-9, or from a Standard-Bluestreak stockist, number VRC-601.
Or, if you're electrically handy, you can make your own solid-state version as described and depicted Here (this is a reprint of Rick Ehrenberg's "Mopar Action" article).
PostPosted: Thu Jul 28, 2005 2:31 pm
Thanks Dan for the part numbers.
PostPosted: Thu Jul 28, 2005 2:55 pm
Just read the article that you suggested. I could do that too. I do have an accetylene torch for the fine soldering. (just kidding)
I worked in automotive for a big utility company for 17 or so years. We were mostly parts changers and maintenence, but ocassionaly had to improvise to get our guys on the road daily.
