It is currently Sat Jun 13, 2026 4:40 pm
PostPosted: Tue Oct 18, 2005 6:46 pm
i have a 1966 dodge dart station wagon and sence ive owned the car the gas guage has never worked ive tried to remove the volt. regulator and bent the tabs a lil to see if it was a contact problem and when i tried to put it back in the volts reg. doesnt seem to wanna go in far enough to touch the cluster, Is it in all the way :? :?:
if it is or isnt i'll fix accordingly next if it still doesnt work where should i start for trying to get my guage to work? ive moved the connector on the gas tank no difference. should i replace the sending unit? if i do and it still doesnt work is it probably the guage.? my speedo stoped working as i was driving and non of my other guages work should i try and swap the whole cluster if i can find one or have it rebuild.
Cuda Progress :D
The dart as it sits now :(
PostPosted: Tue Oct 18, 2005 7:45 pm
...there should be a ground strap between the pickup where it exits the tank and the long metal fuel line. I'd check that it's there and good contact, but I'm betting that the float is sunk. If not that, check the rheostat on the sending unit when you remove it... sometimes those little rivets turn to dust - a teeny tiny machine screw (Radio Shack) can fix that problem.
D/W
EDIT: Just noticed the part where you said NONE of your gauges work - that's kinda suspicious, isn't it?
If it ain't broke, fix it!
PostPosted: Fri Oct 21, 2005 9:17 pm
ok ive seen the lil pickup wire coming out of the tank it runs up into the car should i fallow it and see if it is rotted or anything ive tried touching that gas sending unit guage line :? to the frame to see if the guage moves at all it does not
Cuda Progress :D
PostPosted: Tue Oct 25, 2005 7:46 pm
sounds like the cluster is shot. you have any water damage (discoloration) back there?
-dave
PostPosted: Wed Oct 26, 2005 11:14 am
no water damage, now that i think about it towards the end of my slant driving days(before accident) i noticed the temp guage worked, it would go up if i hit that gas or stayed still, but the car never over heated (not when the guage worked well appeared to work) i think i might pull the sending unit, move the float see if that works, then make my own volts. regulator that i was reading about :P :shock:
Cuda Progress :D
PostPosted: Wed Nov 02, 2005 5:24 pm
I have a simalar problem on my 68 Dart. The cluster works fine exept for
the gas gauge, it only works on rainy/humid days.
PostPosted: Wed Nov 02, 2005 9:25 pm
:shock: really now that is weird :shock: :lol: :?
Cuda Progress :D
PostPosted: Fri Nov 04, 2005 10:53 pm
And mine does just the opposite!
