It is currently Thu Nov 28, 2024 6:40 pm
Post new topic  Reply to topic  [ 29 posts ]  Go to page Previous 1 2
PostPosted: Wed Dec 14, 2005 12:06 pm
You shouldn't flame a new guy about the search feature. All it needs is one gentle mention. p.s. I don't have the right to flame anyone about searching since I ask without searching all the time.
Who's flaming anybody?
PostPosted: Wed Dec 14, 2005 12:33 pm
The Weber DGV/32-36/Holley 5200 carb flows 280 CFM, about exactly the same as a Carter BBD. I suggest getting a spare one barrel intake and boring it out and redrilling the carb mounting holes to accept the two barrel pattern.
The main advantage to the holley 5200/Weber DGV over the BBD is that it is a staged two barrel with the potential for better gas mileage. It would take a bit more fabbing to put on your slant, especially the kickdown linkage, but as you have mentioned is very doable.
PostPosted: Wed Dec 14, 2005 12:56 pm
Which argues against using a 1bbl-to-2bbl "adaptor".
Seems easier to start with a 2bbl manifold, doesn't it?
PostPosted: Wed Dec 14, 2005 1:18 pm
Sure its easier to start with a two barrel intake, but if you are cheap (like me) and have a couple extra one barrel intakes lying around (like me) or just can't find a reasonably priced two barrel intake then it is relatively easy to spend a weekend with an angle grinder, dremel tool, welder, and tap and die set and fab up your own custom two barrel intake from a one barrel. No need to get snippy.
PostPosted: Wed Dec 14, 2005 1:21 pm
I wasn't being snippy, I was asking a question. Sorry if it came across otherwise. No need, my friend, to assume the worst of intentions.
PostPosted: Wed Dec 14, 2005 6:43 pm
I am suprised that someone didn't yell and scream at you to do a search. I guess there is no more information on the topic and anybody that doesn't adhere to the collective mantra need not share.
Your snarkiness is uncalled for.[/quote]
Your absolutely right. I'm sorry about that. I know ther is no excuse. I get kinda bitchy around the full moon time--can't sleep and get ornery.
1967 D100 /225
Some of us catch on slow, and some of us don't.
PostPosted: Wed Dec 14, 2005 6:49 pm
No problem, I haven't been in the best of spirits lately, either. DÃ¥mn winter dark/cold is messing with my head.
PostPosted: Wed Dec 14, 2005 8:20 pm
Come on down here. We have abolished winter.
PostPosted: Wed Dec 14, 2005 9:10 pm
Seems like I read somewhere about someone adapting a single intake to a double. I can't remeber where saw this. Can you help. Part of this whole Weber thing is that intrigues me.
I can't imagine me ever using WOT unless was running from a nuclear blast or a tsunami, and then I'd just be stuck in a traffic jam.
1967 D100 /225
PostPosted: Wed Dec 14, 2005 11:04 pm
There is actually a writeup of this procedure in an old Slant Six News. Give me a couple days and I will scan it and post it for you. THe writeup was done to adapt a Holley 2300 to a stock one barrel maifold, but the principles are the same for the Weber/Holley 5200, just a different bolt pattern.
PostPosted: Thu Dec 15, 2005 6:45 pm
Here you go, I left the pictures big so you can download tem and print them:
ats off to Mr. york for writing this article and submitting it to the old Slant 6 News, but the pictures were fuzzy and he forgot to mention how he fastened the adapter to the intake. I am guessing that he used some self-drilling screws and epoxied and screwed the adapter to te intake. That is what I would recommend.
If you have a welder and are handy with it you could also use this method to fabricate a four barrel intake manifold from a one barrel using some scrap flat iron.
PostPosted: Thu Dec 15, 2005 6:57 pm
Oh, wow, I haven't seen that article in <i>many</i> years! Think it's in Slant-6 News number 32, dark blue/purple cover, Station Wagons and three different 2bbl conversions. My collection of those magazines is stored about 3,500 miles away...I rode in Dave York's car after that conversion. It ran well.
PostPosted: Fri Dec 16, 2005 12:32 am
Reed,
This is super. I like mods like this. When I was a young, before I could drive, the hot rodders just built and finagled their parts togethor. I know that it is convientent to call Summit, but many of us lost our creativity. I think when a guy does stuff like this he learns what he's doing.
Reed, can you email this to me. I can't read the print on my laptop. I don't know if it'll make any difference from the original scan, but I can play with it on Photoshop.
thanks
yeahbut@earthlink.net
Pat
1967 D100 /225
PostPosted: Fri Dec 16, 2005 8:59 am
Pat- you should be able to right-click (in windows) or control-click (on a Mac) and download the pictures to your desktop and then work with them from there. Or:
http://img.photobucket.com/albums/v484/ ... arrel1.jpg
http://img.photobucket.com/albums/v484/ ... arrel2.jpg
Just download them from there.
Looks like I was wrong- the carb was a BBD. Doesn't really matter, the principle is the same. Now maybe people will find a use for all the extra one barrel intakes they have laying around.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 12 guests
