It is currently Fri Feb 28, 2025 5:19 pm
 Post subject: Assine Valve Question
PostPosted: Thu Dec 15, 2005 7:27 am
One would think that with all the time I spend lurking on this forum, that I might have figured this out on my own, but if I upgrade to bigger valves for my street 225, what would the installation entail, and which valves would be recommended. Can I do this in the shop without completely screwing it up?
thanks, josh
64 Dart 170 /6
PostPosted: Thu Dec 15, 2005 8:28 am
1.70/1.44 stainless from sivalves.com
about $10 each
http://www.cardomain.com/id/lncognito
PostPosted: Thu Dec 15, 2005 8:44 am
SI - Check the link-
http://www.slantsix.org/forum/viewtopic.php?t=15078
Probably best to have a shop handle cutting the valve seats in - Thoughts anyone?
 Post subject: Valve Question
PostPosted: Thu Dec 15, 2005 8:59 am
I second the SI Valve choice. I just put their stainless stock size valves in my rebuild. Very nice valves. Highly recommended.
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Thu Dec 15, 2005 9:01 am
So, what would go into putting the 1.70 1.44 valves in place of my stock valves? I'm worried that I may not be able to find a shop that can do it for me.
64 Dart 170 /6
PostPosted: Thu Dec 15, 2005 9:40 am
Anybody that can do a good valve job shouldn't have a problem installing larger valves. This would be a good time to install hardened valve seats for the exhaust.
1966 Signet
Turbo Slant Six
PostPosted: Thu Dec 15, 2005 9:56 am
Awesome. I just called around and there's a shop right up the road from me that can do it all within my meager budget. Thanks for this info.
64 Dart 170 /6
 Post subject: Cool...
PostPosted: Thu Dec 15, 2005 10:27 am
I have a set of those SI Valves the 1.70/1.44/... although they don't "look" much bigger, they are useable without a major over bore, they use a stock lock (no special keepers to buy), and the back cut on the stem is really nice...
Users browsing this forum: Bing [Bot], Google [Bot] and 15 guests
