It is currently Tue Feb 25, 2025 12:02 am
PostPosted: Fri Dec 23, 2005 12:47 pm
Occaisionaly, usually after a long time in traffic, when I step on the gas my car will not accelerate, it does not stall, it feels like a long long long bog. If I take foot off the gas and flutter the pedal a little it eventually kicks back in and off I go.
It only happens when I am reaccelerating from a stop, or on an on ramp. It is very sporadic.
I have fuel flow (electric pump), my car does not stall. Just will not accelerate or rev up.
Any theories (its is a Weber/Holley 5200 Carb, 904 Automatic Trans, Mallory Ign)
Thanks,
Tim
My Swinger gets the Highlight Valet Parking spot over the German sports cars on the Sunset Strip. I love my Mopar.
PostPosted: Fri Dec 23, 2005 2:33 pm
sticky accelerator pump or accelerator pump linkage
PostPosted: Fri Dec 23, 2005 2:38 pm
Or, because it only happens under heat-soak conditions, I'm guessing the accelerator pump chamber is actually boiling or being syphoned dry.
 Post subject: Weber...
PostPosted: Fri Dec 23, 2005 7:12 pm
Those both sound like a viable solutions to start with first...because of the tilt of the ramp and sudden stop you might check your float level.
Usually when you get a bog out like that, it's nice and lean so...you might also see if you have a vacuum leak somewhere too...(rechecked your carb mounting hardware?)
good luck,
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 48 guests
