It is currently Tue Mar 11, 2025 11:58 pm
 Post subject: Heater
PostPosted: Thu Jan 12, 2006 11:51 am
I don't have a heater (no part of one at all) in my '70 Dart Custom. Where can I find one? Do they still make them, or would I have to get an old used one? Thanks for the info.
PostPosted: Thu Jan 12, 2006 12:04 pm
Any '68-'72 Dart, Duster, Demon or Valiant (or '68-'69 Barracuda) will have the heater assembly and parts you need. You may be able to use a '65-'67 unit as well. They are no longer available new. This is not a commonly-robbed part, so anyone parting one of these cars should have the assembly for you. You may need to replace the heater core and/or blower motor.
PostPosted: Thu Jan 12, 2006 1:38 pm
Contributor
If you can't find one from another Mopar, or you would rather have a new unit, they still make aftermarket heaters. Vintage Air has a couple of models that will run between $150-$200 for everything you need.
PostPosted: Thu Jan 12, 2006 3:03 pm
you could also try the flex a lite mojave heater, it's like $150 and works well.
70 Plymouth Valiant 4dr
 Post subject: heater
PostPosted: Thu Jan 12, 2006 6:23 pm
Just in case that wasn't clear, I don't have any heater at all. Not even the heater core, or blower, or anything.
 Post subject: Re: heater
PostPosted: Fri Jan 13, 2006 12:19 am
They know. Thats why they said what they said.
 Post subject: yeah
PostPosted: Fri Jan 13, 2006 10:19 am
Yea, sorry I misread one of the posts and maybe thought I wasn't clear.
Thanks guys!
PostPosted: Fri Jan 13, 2006 12:03 pm
64 is different from 65-67????
I plan on useing a 66 Heater/AC unit in my 64!
