It is currently Fri Nov 29, 2024 6:43 pm
 Post subject: vacuum gauge port.......
PostPosted: Thu Jan 19, 2006 4:00 pm
I'm making an insulation spacer for the carb (BBS) and figure I'd add a port in it for the vacuum gauge I'm adding.......
The vacuum advance port is ported so that won't work; I don't think the PCV hose would be accurate, and I think the #6 intake plug would be unsteady, so
Where's the best location for the port for a steady/consistent reading no matter the throttle position?
1. below the throttle blade on the side that the throttle blade goes up
2. below the throttle blade on the side that the throttle blade goes down
3. below the throttle blade shaft.
4. somewhere else.
I'm thinking 1 or 3
PostPosted: Thu Jan 19, 2006 4:53 pm
Why not just put a pipe plug nipple where the power brake booster line goes on PB cars.
PostPosted: Thu Jan 19, 2006 5:02 pm
That's the #6 intake runner........... I think the gauge would fluctuate because it would mostly see the signal from the #6 cylinder
PostPosted: Thu Jan 19, 2006 5:12 pm
not sure why the pcv nipple wouldn't be accurate as it pulls manifold vacuum all the time. vacuum gauge readings will never be smooov. if size is the issue; is there another, smaller nipple at the carb base that pulls manifold vacuum?
-james
PostPosted: Thu Jan 19, 2006 5:26 pm
While I was playing with mine, I don't remember there being a measurable difference in vacuum between the #6 runner and the intake side of the EGR port (where I run my PCV valve to). It would seem that so long as you are below the throttle blades, the vacuum signal should be nearly equal no matter where you are.
PostPosted: Thu Jan 19, 2006 5:33 pm
-james
A 64 BBS doesn't have another nipple. There's a nipple for the vacuum choke pull-off, but I think that's venturi vacuum, not manifold vacuum.
Another problem with the PCV is the big hose/tiny hose issue.
Also, I'm not sure, but because there's air flow thru the PCV hose, it may have an effect on the reading
PostPosted: Thu Jan 19, 2006 5:37 pm
You'd think so........., but I'm not sure. I'm just thinking that for when I get around to playing with the metering rods I'd want the vacuum gauge to be similiar to what the carb sees, and the closer to the carb the better, and without some possible weird airflow effects of the throttle blade.
I'm just not sure where that would be
PostPosted: Thu Jan 19, 2006 6:41 pm
The #6 runner is fine. If you don't like that, then put a "T" fitting in the choke pulloff hose and tap in there.
PostPosted: Thu Jan 19, 2006 6:55 pm
in my experience: never share a small port like choke pulloff for a vacuumeter. Mine is connected on a small T right where the brake booster is connected (steady reading) but very close to the manifold. in fact I used one of these brake booster things that has extra small diameter hose connectors for other vacuum related applications on modern cars (hideaway lights, heather control, you name it)
if you ain't using that choke pulloff, that port would work just fine. (Say if you converted it to manual choke as I did)
Juan Ignacio Caino
PostPosted: Thu Jan 19, 2006 6:57 pm
Ok, what NPT size is the plug on the #6 intake runner?
PostPosted: Thu Jan 19, 2006 9:27 pm
My vote: Tee into the choke pulloff line. It is not ported or venturi vacuum, it is manifold vacuum. PCV line works just as well, but it's easier to tee into lines of roughly equal diameter.
PostPosted: Fri Jan 20, 2006 4:08 am
I've teed into this line and I get non consistent readings. My guess is that's too small to share. I know is mani vacuum but if you use it to feed both the choke pulloff and the vacuumeter somehow the vac readings hurt.
Juan Ignacio Caino
PostPosted: Fri Jan 20, 2006 7:18 am
I don't know why you would get non-consistent readings unless either the passage in the carburetor was partially blocked or your choke pulloff diaphragm was ruptured. Vacuum should be fairly constant and consistent no matter where you tap into it.
PostPosted: Fri Jan 20, 2006 7:36 am
Well, as the pull-off moves it will probably give bogus readings because you are changing the volume of the system. At that particular point, it that would be a significant change in volume. Once it's warmed up, however, there should be any changes.
PostPosted: Fri Jan 20, 2006 7:42 am
Actually, the choke vacuum pulloff only moves once-- on startup when the plunger is sucked back by the vacuum. After that the choke rod and pulloff spring move the choke the rest of the way open. The vacuum only pulls the choke butterfly open far enough for the car to run without stalling out, but that is the limit of its travel.
Users browsing this forum: Semrush [Bot] and 2 guests
