It is currently Fri Nov 29, 2024 5:30 am
PostPosted: Thu Jan 19, 2006 11:23 pm
Got an occasionally speedo needle vibration (yep only sometimes). It's a fast cycle, but it's only a 2mph arc.
So what's best?
1. gear lube
2. white grease
3. moly grease
4. wheel bearing grease
5. bicycle cable lube (with teflon)
6. a mix of some/all of the above
And is there a way to clean out 42 year old gunk in the cable sheath?
The bicycle cable lube (with teflon) works great on my motorcycle's throttle and clutch cable, plus I can just drip it into the cable.
PostPosted: Fri Jan 20, 2006 12:11 am
I don't think anything you can "drip" is going to work well for a speedo cable.
I used a very liberal dose of synthetic chassis grease on mine and it worked well. I could of sworn I was at an auto parts store once and saw a can of lube specifically labeled for speedo cables.
Squirting brake cleaner into the cable and let it run out the other end will probably get it clean enough. Maybe run a length of wire through it if you want to be more thorough?
PostPosted: Fri Jan 20, 2006 2:07 am
How hard would it be to just replace the cable?
It wasn't too bad on my truck.
I did shoot a liberal amount of white litium grease down as I fed the core.
I probably could have put a lot more in and been even happier as it still wobbles.
PostPosted: Fri Jan 20, 2006 2:50 am
The 42 year old cable only has 16900 miles on it, so I think the cable is fine, but the lube as dried out............
Plus I've never had good luck with replacement cables, the new lubed cable never was as smooth as the original (that is until the original broke)
PostPosted: Fri Jan 20, 2006 4:42 am
I always used white lithium grease. Not the spray can though; you used to be able to get it in a tube, like toothpaste. I would fill the cup at the top of the cable housing then push the cable down through the blob of grease. Keep the cup full until you get to the last few inches then wipe off the excess before installing the cable
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Fri Jan 20, 2006 5:54 am
I've always pulled the core out of the cable and cleaned it with brake/carb cleaner. After the core is cleaned reinsert while still slightly wet with solvent spin by hand remove core and repeat until it comes out fairly clean. As for lube a thin coat of graphite based antisieze to the entire length of the core. The core wire usually will only come out through the interior end of the cable.
PostPosted: Fri Jan 20, 2006 7:33 am
When my dad's speedo acts up like that, he dumps some powedered graphite down the cable housing. Seems to work every time for him.
PostPosted: Fri Jan 20, 2006 2:13 pm
Yep, I do the samething once every winter. That's when my speedo gives the most trouble.
82 D150-225/727
02 Dakota-3.9/5 speed
 Post subject: speedo cable
PostPosted: Mon Jan 23, 2006 3:51 pm
A word of warning- don't pull hard on the cable when you remove it to lube it, or it will stretch and then bind up after you put it back in because it's now longer. I did that, but fixed it using a Dremel tool w/ #409 bit cut off about 1/8" from the end.
I've had good luck with the graphite filled grease made for that purpose.
