It is currently Mon Nov 16, 2026 3:41 pm
Post new topic  Reply to topic  [ 69 posts ]  Go to page 1 2 3 4 5 Next
 Post subject: windage tray
PostPosted: Thu Jan 26, 2006 7:04 am
will I benefit from using one on the street
PostPosted: Thu Jan 26, 2006 7:23 am
No, not unless you plan on winding your engine above 5000 RPM most of the time.
82 D150-225/727
02 Dakota-3.9/5 speed
 Post subject: Re: windage tray
PostPosted: Thu Feb 02, 2006 10:19 pm
Yes.
PostPosted: Fri Feb 03, 2006 12:16 pm
Windage trays are *always* a benefit. Even at 2000 RPM, there's a lot of wind drag and oil whipping around a crankshaft. Why they weren't included on all engines, I'll never know.
The more appropriate question for you whether a windage tray is worth the cost and hassle of installing it in your engine. They're cheap and easy to install for big-block v8s (they bolt in between the oil pan and block). They're cheap and a good bit harder to install on small-blocks (have to remove a couple of main bearing caps and replace the bolts with special ones reinstall the caps, and then the tray).
But I gather that for a slant-6, they're not so cheap and also not so easy to install. Given that, the benefit is probably not worth it.
PostPosted: Fri Feb 03, 2006 1:29 pm
are any currently in production?
I have searched the site and all I could find is someone who makes them occasionally in his off-time
how about the crank scrapers people? anyone try their stuff?
-dave
what part of "illegal" is so confusing???
PostPosted: Fri Feb 03, 2006 3:08 pm
I have both the tray and the scraper. Would I take the time to do either on a daily driver motor?
No. It ain't worth it. :shock:
Mike will make both trays and scrapers, but I don't believe he did any this year.
My scraper came from the guys in Florida. I think Mike's are cheaper because he gave me shyt about paying too much. It did require a lot of massaging to get it to fit, but that isn't unusual. The tray did too. :D
PostPosted: Fri Feb 03, 2006 3:15 pm
If you make the scraper out of aluminum, can't you just install it and let the crank grind it down to the correct size??????????
:twisted: :roll: :wink:
PostPosted: Fri Feb 03, 2006 3:38 pm
yikes.
imagine that aluminum rolling around in the system.......
(yes I know you were kidding.)
PostPosted: Fri Feb 03, 2006 3:40 pm
yikes.
The oil filter will pick it up............ (unless it's a Fram :? )
PostPosted: Fri Feb 03, 2006 4:54 pm
The guys down here in Florida, have one made of teflon, that is fitted that way.
PostPosted: Sat Feb 04, 2006 9:36 pm
Scrapers can sometimes take a while to adjust properly.
Last edited by Kevin Johnson on Sat Jan 09, 2010 1:13 am, edited 2 times in total.
PostPosted: Sat Feb 04, 2006 10:05 pm
Sorry about the "shyt".
Last edited by Kevin Johnson on Sat Jan 09, 2010 1:15 am, edited 2 times in total.
PostPosted: Sun Feb 05, 2006 7:15 am
Kevin,
I'll be ordering one of your Slant scrapers, and will likely get another soon. Thanks for supporting our engines!
PostPosted: Sun Feb 05, 2006 7:39 am
i just added one of kevin's scrapers to my 318 and thought it a good upgrade. over the years i have often heard about scrapers being as effective as a windage tray without any special hardware (use in place of your pan gasket. yes i did have to fit it to my engine (show me two bottom ends identical to the last millimeter) and no it wasn't a real pain in the ass. but i wouldn't recommend doing it in the car. although somebody could possibly make their own in a day or so, i don't think it would be worth it considering the $50 pricetag for an off the shelf performance part that's already sorted out. i'm going to order more for my future slant projects.
-james
PostPosted: Sun Feb 05, 2006 11:46 am
Now, about the "shyt"...
Over the past two years I think I have sold about 15 sl6 scrapers in total -- worldwide 170/225 inclusive. That probably just barely covers the amount of time I spent in transporting engines and design.
Kevin, you must remember the context of the conversation. When I bought your scraper I did not know that Mike made them too. My comment has nothing to do with the price of your scraper. I feel it was worth the money even though it did require a lot of massaging to clear the crank and rods.
It appears to me that Mike would have sold me one for less. Since Mike helps sponsor my car I hope you can see his position.
He is putting your scraper back in my motor during the freshen-up too.
Mike thought yours looked good too by the way.
I would like to know any positive data on how much good they do on a street motor though. I used one because my motor regularly sees over 6000 RPM. :shock:
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 5 guests
