It is currently Mon Nov 23, 2026 3:40 am
 Post subject: oil pan leak
PostPosted: Tue Mar 07, 2006 10:03 am
I'm about to pull my hair. I'm having trouble fixing and oil leak. The car is a 73 Duster with a 225.I've replaced the oil pan gasket 4 times. I've cleaned both the block and oil pan, dimpled the oil pan bolt holes. I've even used the right stuff. It still leaks. Any suggestions?Thanks
Move
Over
People
Are
Racing
PostPosted: Tue Mar 07, 2006 10:15 am
It may seem obvious, but be sure the front section, with the big rubber tabs, is oriented correctly. The tabs go inside to form a seal between the oil pan and timing cover.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Tue Mar 07, 2006 2:54 pm
Where is it leaking? Are you sure its not coming from the rear main seal or balancer seal in timing cover?
I would give the whole engine a through washing, use de-greaser then rinse with hose. Jack the car up, run it, and lay under it until you see the first drop. For all you know it could be a leaky head gasket that trails all the way down to the pan.... been there done that ;)
PostPosted: Thu Mar 09, 2006 9:54 pm
After you do the washing add a fluorescent tracer to the oil (auto supply stores have this product). Buy a "black light" incandescent bulb from a hardware store and shine it around at night after idling the engine. You should be able to see glowing from where the oil is coming.
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 3 guests
