It is currently Thu May 21, 2026 4:56 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 8 posts ]
PostPosted: Mon Jul 23, 2001 5:41 am
A buddy of mine recently finished a 3 yr resto on a 1938 Dodge business coupe with rumble seat. RARE,RARE! It has a 3speed and driveablity is a
problem. The flat head six doesn't smile on the R's, and top speed is ~50mph. Rumor has it that there was a 4 spd(OD)
trans available for that year. Any info would be appreciated.
PostPosted: Mon Jul 23, 2001 6:03 am
: A buddy of mine recently finished a 3 yr resto
: on a 1938 Dodge business coupe with rumble
: seat. RARE,RARE! It has a 3speed and
: driveablity is a
: problem. The flat head six doesn't smile on the
: R's, and top speed is ~50mph. Rumor has it
: that there was a 4 spd(OD)
: trans available for that year. Any info would
: be appreciated.
Yes, there is an OD tranny for the flathead 6. Will dig up specifics and try to get back to you later today.
---Red
Torr66@aol.com
 Post subject: Re: Also.......
PostPosted: Mon Jul 23, 2001 11:23 am
: The rear has a 3rd member and looks ~ to an 8 3/4. What is it? Are gears available?
PostPosted: Mon Jul 23, 2001 4:21 pm
Try posting to the P15/D24 message board ('42- early '49 Dodge and Plymouth). Many parts exchange from the '30s to '60 cars and trucks.
O/D units are popular swaps and might be a little spendy.
<A HREF="http://207.114.216.163/~gtk/wwwboard//index.html">http://207.114.216.163/~gtk/wwwboard//index.html</A>
: driveablity is a
: be appreciated.
PostPosted: Mon Jul 23, 2001 9:46 pm
: Yes, there is an OD tranny for the flathead 6.
: Will dig up specifics and try to get back to
: you later today.
: ---Red
I know I have a good article on this someplace, but it may take me awhile to put my hands on it (that's the trouble with us "old timers")! In the mean time, here's a lead for you:
<A HREF="http://www.classiccar.com/chatsforums/f ... oupID=1009
copy and paste entire URL into your "go" bar, then scroll down to 6/15/01 entry by "Pete", subject: "overdrive"
I'll get back to you. Good luck.
---Red
Torr66@aol.com
 Post subject: Re:Thanks Red! *NM*
PostPosted: Tue Jul 24, 2001 9:49 am
PostPosted: Tue Jul 24, 2001 1:48 pm
Best I can make out, 1953-56 Dodges & Plymouths are the cars which had manual overdrive as an option on the Mopar flat 6. If you find one, it will likely not be cheap as I understand they are getting pretty rare...and lot's of people want them to keep the rpms down when highway/freeway driving their antique. Stock rearend on your car was a dropout 3rd member type...look for a flat spot on the bottom of the 3rd member just right of center: gear ratio should be stamped there (under 60+ years of crud!) and could be anything from 4.3 to 3.5. If it's 4.3, that would explain alot of the problem r.e. top end! Finding a higher rear gear would be easier (than an OD) as this type rearend or similar was used all the up into 50s (as was the flat head) If you want to e-mail me a mailing address, I have other info I could photocopy and send you which might be of help.
--Red
Torr66@aol.com
PostPosted: Tue Jul 24, 2001 2:54 pm
These guys might also be able to point you in the right direction...they've obviously given the problem some thought:
<A HREF="http://www.gearvendors.com/index.html"> ... ex.html</A>
<A HREF="http://www.gearvendors.com/articles/hot ... ex.html</A>
<A HREF="http://www.gearvendors.com/agmanual.htm ... al.html</A>
Good luck
---Red
Torr66@aol.com
