| PowerPipe-DC (True Flow Header Design) https://slantsix.org/forum/viewtopic.php?t=39043 |
Page 8 of 12 |
| Author: | Jester [ Sun Apr 25, 2010 11:55 pm ] |
Wow, I don't know which one to order for my '72 Dart. I'll just be using a supersix intake and 2bbl carb, it's automatic, has power steering and a mini-starter. I'll be getting the local muffler shop to fabricate an exhaust system, so I guess whatever's easiest for them. Would prefer one of the duals. What would be recommended? It'll be stock for now and then get slightly warmed over |
| Author: | Mister Twister [ Mon Apr 26, 2010 2:55 am ] |
Quote: more concerned with starter there is plenty of room also will it work with the offy dual carb intake manifold starters on trucks are lower than cars
How much drop clearance do you need |
| Author: | Mister Twister [ Mon Apr 26, 2010 3:01 am ] |
Quote: keep up the great work....lppks like you got some good products here
Thanks getting better with age! Like wine.
keep on roddin' |
| Author: | Mister Twister [ Mon Apr 26, 2010 3:22 am ] |
Quote: Wow, I don't know which one to order for my '72 Dart. I'll just be using a supersix intake and 2bbl carb, it's automatic, has power steering and a mini-starter. I'll be getting the local muffler shop to fabricate an exhaust system, so I guess whatever's easiest for them. Would prefer one of the duals. I have installed all of them in my Duster. For what you plan to do, the PowerPie-DC should do the trick. This was just put on Dodge Girls Duster last week. We took off the Hookers off and installed the PP-DC the sound is allot deeper tone then it was, and has more grunt off the line. She is running a stock 225 with the super six set up as well. We ran the same set upon my TwIsTeR starting in the low 20's dropping to low 16's with just some bolt ons. What would be recommended? It'll be stock for now and then get slightly warmed over ![]() ![]() Have a good day Don. |
| Author: | Jester [ Mon Apr 26, 2010 12:38 pm ] |
sounds good to me. If I decide to turn my slant into a high-performance motor, will this pipe accomodate that for the most part? |
| Author: | Mister Twister [ Wed May 05, 2010 2:55 am ] |
Quote: sounds good to me. If I decide to turn my slant into a high-performance motor, will this pipe accomodate that for the most part?
Yes they will work fine. If you plan on running 13's or faster I would go for the True Flow design. Still waiting on Charlie for the early model 170 application? Here is the first turbo design, True Flow to fallow soon. We are making X and Y pipes as well. These will be ready for sale this week. Talk to you later Don Have a good day all Don. |
| Author: | Wesola78 [ Sun May 09, 2010 7:11 am ] |
Quote: Quote: Wow, I don't know which one to order for my '72 Dart. I'll just be using a supersix intake and 2bbl carb, it's automatic, has power steering and a mini-starter. I'll be getting the local muffler shop to fabricate an exhaust system, so I guess whatever's easiest for them. Would prefer one of the duals. I have installed all of them in my Duster. For what you plan to do, the PowerPie-DC should do the trick. This was just put on Dodge Girls Duster last week. We took off the Hookers off and installed the PP-DC the sound is allot deeper tone then it was, and has more grunt off the line. She is running a stock 225 with the super six set up as well. We ran the same set upon my TwIsTeR starting in the low 20's dropping to low 16's with just some bolt ons. What would be recommended? It'll be stock for now and then get slightly warmed over ![]() ![]() Have a good day Don. |
| Author: | Mister Twister [ Mon May 10, 2010 4:15 am ] |
I had the pipes Y to one pipe around tranny mount. I ran two tail pipes tho. Some people say true duels with X pipe is the best, then others say the Y is the way to go. Only testing will tell if this configuration will work. What do you all think |
| Author: | oldblue [ Mon May 10, 2010 5:20 am ] |
Please get a sound recording of the x+y pipe when installed. |
| Author: | Mister Twister [ Wed May 19, 2010 2:15 am ] |
Quote: Please get a sound recording of the x+y pipe when installed.
I will be glad to do this for you oldblue. We should have the car back together by next weekend |
| Author: | Joshie225 [ Wed May 19, 2010 7:43 am ] |
If the muffler has sufficient flow capacity a Y-pipe makes just as much power as duals with an X-pipe. It also weighs less and costs less. |
| Author: | Matt Cramer [ Wed May 19, 2010 9:07 am ] |
The idea with both X and Y pipes is to combine pulses. I don't expect a benefit to using both together myself. |
| Author: | hellion_locdogg [ Wed May 19, 2010 3:41 pm ] |
Is it possible for you to make an X w 2'' in to 2 1/2" to 2" out? Just a thought, not sure I want 2" restriction with true 2" duals. I currently have an H, even though I asked for an X. I didn't bitch though because the rest of the exhaust looked superb. ,Cliff |
| Author: | Evilsizer [ Fri May 21, 2010 4:46 pm ] |
any chance for dyno numbers to compare to the power pipe or PP-DC? |
| Author: | Mister Twister [ Sat May 22, 2010 3:41 am ] |
Quote: Is it possible for you to make an X w 2'' in to 2 1/2" to 2" out? Just a thought, not sure I want 2" restriction with true 2" duals. I currently have an H, even though I asked for an X. I didn't bitch though because the rest of the exhaust looked superb.
Yes that would not be a problem.
,Cliff |
| Page 8 of 12 | All times are UTC-07:00 |
