Closed chamber head....
https://slantsix.org/forum/viewtopic.php?t=65770
Page 8 of 9
Author:  StrokerScamp [ Sat Apr 03, 2021 12:54 pm ]
Post subject:  Re: Closed chamber head....
It's interesting that the exhaust side is a more responsive port than the intake. On the intake, it's pretty much all done by .400 lift.
Yup. S'kinda all I really need. Only going to run .485 lift with about .020 subtracted for lash. Once the valves are back cut and the valve job touched up we should be right in the ballpark.
Although plenty of people do it, tying to go much over .500 lift on a slant six head starts getting counter productive, IMO.
Author:  StrokerScamp [ Sat Apr 03, 2021 7:10 pm ]
Got the guides cut to the diameter seals I'm using and opened the sprAng seats up a little to accept the Comp 911 big block sprAngs. It's funny, one of the differences of this head compared to all the others I have.....over ten.....I ain't counted lately lol, all the others I have will take a spring bigger than the 1.550 diameter, while this head did not quite fit the Comp 911....I could JAM it down in there, but it needed more room, so I opened the spring pockets just a tad. Didn't go DOWN any mind you, just enlarged the diameter, cut the guide's diameter down a tad and removed the step at the base of the guide as well. But Jerry was right. This head is hard as a ROCK. I had a brand new Comp guide and seat cutter and it took a while.
Author:  GregCon [ Sat Apr 03, 2021 7:38 pm ]
I've had numerous machine shop guys tell me Mopar iron is way tougher than Chevy iron. I think that's been 'proven' as the nickel content is higher.
The example I've heard, other than how hard it is to machine, is a Mopar block might show .010" wear on the cylinders, while a Chevy might show 3X as much under similar conditions.
Author:  volaredon [ Sat Apr 03, 2021 8:01 pm ]
yup. Ken at Oregon told me the same thing, when he had my cam and we were talking about surface treatments (or not?) that they do when a cam is done being ground, he said that Mopar steel is "pretty tough" compared to some of the others/ namely Chevy.... Look at how many Mopars had cams go flat vs How many Chevys have, over the years....
Besides volume of parts popularity/sold/ Chevys being so cheap to rebuild.... now maybe the truth is coming out.... no wonder Chevy parts are so cheap.
Author:  StrokerScamp [ Sat Apr 03, 2021 9:11 pm ]
Right, I've heard machinists say similar all my life. The two heads I had milled recently.....the one I ended up "accidentally" having .155" milled off AND this closed chamber head, it only was milled .010"....the same guy did both and he also commented on how hard they both were. I've hear other machinists say similar. Petty interesting stuff.
Author:  StrokerScamp [ Sat Apr 03, 2021 9:13 pm ]
Yes, I've spoken with Ken about that same thing......very recently in fact. He said that all the Chrysler factory camshafts were hardened almost clear to the core. We were discussing him grinding a small solid roller on a factory solid flat tappet core......and he's going to do it for me.
Author:  StrokerScamp [ Tue Apr 13, 2021 11:37 pm ]
A little off topic, but I thought yall might like it. I got the milled head motor in the car and running. Actually sounds nastier than I thought it would. This one is right at 10:1 and that's the reason for the big cam so it will be pump gas friendly at 7.9 dynamic. .465 lift, 250 @.050 duration ground on a 108. QFT 450 on an Offenhauser intake with a ported exhaust manifold also opened up to 2.5". This video is just with the TTI head pipe and nothing else. I should have the rest of the TTI system before the end of the week. The closed chamber head motor may get put on hold a little longer if this one ends up running like it sounds. All I have left is the rest of the exhaust and getting the throttle cable attached....and getting the timing sorted out. I'm going to have to enlarge the slot in the bracket under the distributor, because with the camshaft timing advanced the 5* by the card, the ignition timing is advanced too much and It's out of slot to retard it. If I flip it back one tooth, then it's too far retarded and won't advance enough. It's right in the middle of no man's land, but I'll get it sorted out. I'd LOVE to find the 81 and up distributor hold down, but I know that's a fat chance. I may modify a Chevy small block one to work. Anyway....enough rambling, here it is.
https://www.youtube.com/watch?v=SMtKq3vBF3c
Author:  GregCon [ Wed Apr 14, 2021 5:27 am ]
I assume you know the dist clamp has two slots...and the one that attaches the clamp to the dist body can be adjusted as well? I think there is enough movement to cover one tooth, so no matter what you can always get the dist where you want it.
Author:  DusterIdiot [ Wed Apr 14, 2021 6:23 am ]
Post subject:  D
D
Author:  StrokerScamp [ Wed Apr 14, 2021 3:09 pm ]
Oh yeah. I know. Trust me. I'm either going to have to elongate the slot under the distributor, or get the later clamp.
Author:  StrokerScamp [ Wed Apr 14, 2021 3:12 pm ]
You might not want to listen to Ken on that topic...as the stock flat tappet camshaft won't hold up to the hardness of the roller wheel on the lifter...I know 3 of us that have done it...
Doc did one with a nitride coating (which ended up crumbing after the underlying base metal on the lobe compacted and left nitride coffee grounds in the oiling system), Dave Mueller who
used one to drag race with no coating (he strictly fires the car up for warm up and the 1/4 mile then shuts it down right afterward and gets towed to the pit to minimize wear - Ken did tell Dave that they wouldn't last long...). I have 2 on my shelf that are gathering dust since the limited run of billet camshafts Ken had done for us 10 years back. Just note to get the lobe right on the regrind the base circle is almost the diameter of the cam shaft main core.... If you want to experiment I might make a deal on those 2 sticks if interested.
FYI.
Thanks. It's a long way off yet, so there is still a lot of time to figure it out. I don't even have lifters yet, so I've not done anything concrete. The biggest thing is, I'm not going to do anything so far out of the box as to take a chance on hurting that head.
Author:  SlantSixDan [ Wed Apr 14, 2021 5:23 pm ]
About camshaft hardness and wearproofness: This might be worth a read and followup. It's from 34 years ago, and the process has quite a bit more evidence backing it up now than it did then (including the brake rotors on my daily driver, which permanently quit warping once I put in cryo-treated ones)
Author:  StrokerScamp [ Wed Apr 14, 2021 6:08 pm ]
Greg, I wanted to come back and thank you. I kept thinking about your comment all night and agreeing with it over and over. When we got back home from supper, I went out and retarded the distributor one tooth and that did it! Sometimes I'm stupid hard headed.....but I do appreciate your comment. I was able to get it at 15* BTDC and it seems to like it. I'll get the rest of the exhaust on it this week and drive it and see what it likes. It might need a little more. We'll see.
Author:  StrokerScamp [ Wed Apr 14, 2021 6:09 pm ]
As usual Dan, you always have some great information! Thank you!
Author:  DusterIdiot [ Thu Apr 15, 2021 6:20 am ]
Post subject:  D
D
Page 8 of 9 All times are UTC-07:00
