| 1972 Dodge Colt https://slantsix.org/forum/viewtopic.php?t=63924 |
Page 73 of 83 |
| Author: | slantzilla [ Sun Dec 22, 2024 8:51 pm ] |
| Post subject: | Re: 1972 Dodge Colt |
Can you put a spacer on the lower ball joint? |
| Author: | hyper_pak [ Mon Dec 23, 2024 7:49 am ] |
I have looked and don't see anything that would work.The lower joints are not the rebuildable type. They do sell balls with longer tapered shanks for rebuildable joints. |
| Author: | hyper_pak [ Fri Jan 03, 2025 3:59 pm ] | ||
| Post subject: | Re: 1972 Dodge Colt | ||
Going to the machine shop on Monday.
| Author: | slantzilla [ Fri Jan 03, 2025 10:13 pm ] |
Hope you can get it straightened out Stan. |
| Author: | hyper_pak [ Sat Jan 04, 2025 9:55 am ] |
Me too |
| Author: | Rick Covalt [ Sat Jan 04, 2025 10:26 am ] |
What is the fix Stan? Machine shop sounds serious! |
| Author: | slantzilla [ Sat Jan 04, 2025 7:25 pm ] |
Can you fab longer A-arm brackets to get a better angle on the lower ball joint? |
| Author: | hyper_pak [ Sun Jan 05, 2025 9:51 am ] |
That was mentioned on FABO. But at this point it would be lipstick on a pig. Strange used to make a mini-strut, I saw one a while back for sale. But they are old parts now and need rebuilding. I will just sell some more parts and save up for real struts and be done with it. Or find more horse ponies. Thanks Pops |
| Author: | slantzilla [ Mon Jan 06, 2025 4:07 pm ] |
With no travel in the front it will always be hard to hook. A good strut front end will make a big difference. |
| Author: | hyper_pak [ Thu Jan 09, 2025 5:32 pm ] | ||
Get Ready
| Author: | Team Green [ Thu Jan 09, 2025 6:10 pm ] |
426 Mo-Kan comes through again for the Mo-Par guys! Jr. |
| Author: | Rob Simmons [ Fri Jan 10, 2025 6:46 am ] |
Very classy indeed. |
| Author: | hyper_pak [ Fri Jan 10, 2025 8:41 am ] |
How can we get those rockers delivered? When do you start classes? When is the prom? |
| Author: | Rob Simmons [ Fri Jan 10, 2025 3:22 pm ] |
I can mail them to you Classes start April 1st ( No clue |
| Page 73 of 83 | All times are UTC-07:00 |
