It is currently Tue Nov 24, 2026 8:19 pm
Post new topic  Reply to topic  [ 134 posts ]  Go to page Previous 1 … 5 6 7 8 9
PostPosted: Tue Mar 19, 2024 6:18 am
Whilst futzing with my ongoing '62 Valiant wagon project saga, we were driving the '69 Swinger a few times over the last week as the weather was nice.
I bought and installed reproduction Mufflers and a tailpipe for this car maybe 1̶0̶ y̶e̶a̶r̶s̶ a̶g̶o̶? [edit] I double checked the recipt from year one and it was 14 years ago - 2010 to be exact! Man time flies as you approach the old man parts of life! [/edit] the left muffler rotted away in the Left front corner as the exhaust on this car never gets real hot, so it collects a lot of moisture, especially on colder days.
Eventually I will buy another reproduction muffler, but it seems that they are more for show rather than actual driving, cause they rust quick in my application.
So I made a patch from an old ''63 Dart hood - Keep your MoPar all MoPar! :D It's not pretty, but it does work. While I had the hot glue gun turned on and working, I also placed a bung in the exhaust cutout cap for an O2 Sensor that I can add or remove when needed.
PostPosted: Tue Mar 19, 2024 7:30 am
Good work Greg. :mrgreen:
PostPosted: Tue Mar 19, 2024 7:59 am
I have run duals on my slants that were on the road, but never was a big fan.
On the wagon I decided on the one larger pipe and muffler.
I think that was a better solution.
I was toying with the idea of the Commando V8 resonator and a body cut-out, but didn't do it.
I still have the resonator.
PostPosted: Tue Mar 19, 2024 8:17 am
Just a question Greg, do those mufflers have weep holes in them?
My Duster used to collect gobs of water in the bottom of the muffler. I drilled an 1/8" hole just in front of the back seam and it stopped it.
PostPosted: Tue Mar 19, 2024 3:25 pm
I drill holes in every muffler I install, including these. Repops / Walker/ AP never seem to have that added manufacturing step.
Sometimes I will also drill on the low spots after the muffler in the tailpipe/ tail spout also.
I figured that this one had a low spot in the front corner, so after welding on the patch, i drilled one it the front too. Goofy, but according to the evidence that might help drain some of the condensation.
PostPosted: Tue Mar 19, 2024 3:30 pm
I agree. I want to ( for now) keep it that way.
I will likely build a skookum correct exhaust for this car some day.
Back when I built this car, I was 19-20 yeats old with no money or skills so stock pipes and muffler shop help was what I used.
PostPosted: Thu May 02, 2024 8:13 am
I have been driving the car again a bit during the super nice weather we are currently having. The family and I went out to the ice cream shop last night. Continuing my carb tuning that I started back in August-October 2023: I had every change that I made last Fall on a notepad to keep track of impressions and perceived effects of those changes.
There are still little flat spots in the fueling at times, and I found that the engine went into a pretty bad stall at WOT - Like the fuel pump cut out or something... Found that since trimming down the primary circuit for leaner performance and proper idle, the secondary jetting was too lean. I went from 0.095" secondary jets to 0.104" secondary jets and now the WOT operation is correct again.
After the Ice cream shop, I did a quasi-non-permanent install of the O2 Sensor in the Exhaust cutout. I drilled the cutout cap and welded a mild steel bung to it in mid-March 2024. I have had the O2 Gauge sitting in the parts queue ready to go since probably last fall as well.
After installing the AFR Gauge I found that the engine Idled consistently at ~12.5 AFR and the WOT also seemed good in the mid 12's
Temporary installation of the Sensor:
Temporary wire run:
Mounting solution for the Gage was:
Put it in the ashtray, No tape, zip ties, or fasteners are needed.
PostPosted: Wed Jul 02, 2025 6:32 pm
It has been a while since the last update - Busy with life and other projects.
The O2 Sensor tuning was a great success with this car - Idle is better than ever and Part / Wide open throttle is about as good as a carburetor will allow.
I believe shortly after I posted here last, the other muffler failed. I patched that one up the same way with some spare sheet metal from a trashed '64 Dart hood.
Rock auto does not list any muffler as available for a '69 dart with any engine combination. I found a universal Muffler that is waaaaaay cheapter than the Restoration Mufflers from Year One or Accurate LTD., which are pricey and seem to fail somewhat quickly for me.
I believe SlantSixDan Has recommended this muffler in the past as it fits Jeep XJ Cherokee's too.
Walker 18113 has the same dimensional case length of an OE v8 A body Muffler and is 2 1/4" in and out. It can be easily modified to fit any A Body with any engine combination with some pipe adapters as needed.
The In and out tubes are long and will need cut to length for my application.
Here is a comparison of the two units before I cut off the extra length on the Walker 18113
Here is a side by side of the old patched up unit and the Walker 18113 with the ends cut off to my specification.
I am picky about muffler and Exhaust work in general - I want clamps and slip fits for future removal cause I tend to keep stuff for a while.
I hate fully welded systems that are installed quick and dirty and need to be cut apart to service the transmission or replace a component.
Both Patchy Units removed:
2 New Walker 18113's installed:
Don't Forget to drill some weep holes, Bro!
PostPosted: Thu Jul 03, 2025 3:08 am
Rock auto has that muffler at a really good price. Search by part number not vehicle. Didn't look at shipping cost.
PostPosted: Thu Jul 03, 2025 3:24 am
Yes they do.
You can get 6-8 of these for the price of one year one or accurate ltd units.
PostPosted: Thu Oct 29, 2026 5:59 pm
Better Late than never I guess:
Some of the guys at FABO wanted to know what the mufflers sounded like... so Here it is.
PostPosted: Thu Oct 29, 2026 6:42 pm
Last weekend we went on a family trip to the around the elevated ridge areas near here. It was beautiful day, as Ava and I took the Duster to the mountains for a sunrise, then we came home and swapped to the Dart for the rest of the day.
We headed south and up into the ridges for Laurel Caverns. It is one of the only local caves around here. It was run By the Cale Family as a private enity from 1964 and in 2026 it was donated to the state. It is now a state park, mostly underground.
Great day for a picnic.
Supposedly on a clear day you can see to Pittsburgh from here some ~50 Miles away.
This is High Ridge County round here. The Alleghney Front runs from WV and Maryland Up 100-200 Miles North of here. Many places along the way are windy most of the year. Lots of Wind turbines exist here.
Just south of the wind turbines on skyline drive is a good spot for glamour shots..
Car is not the star today.
Then after 200 more pictures we decided to go to coopers rock, WV, about 20 miles south.
More back roads and Tree canopies in the fall.
My car sticks out like a sore thumb in the sea of hipster suv's and mega lifted trucks in the Wooded Parking Lot, which was very full at ~3PM on this Saturday. There is maybe room for 200 cars. there were 700 there. everywhere, sides of the road, and in every siding / trail head too! We were lucky to find a spot!
My grandfather used to bring me here sometimes as a kid. It has not changed. Rock outcropping looks over the cheat river valley some ~500' below you. It is nice this time of year. It is brutal and desolate in the cold and wind.
I did not get any pictures of the valley this time. But I got some soaring big birds...
Next we headed to dinner and then a band show. The band I work with won the show. Most of my students are featured members in the show. A nice way to end the week for everyone.
It is safe to say that I was the only one there with a '69 Dart at the band show too!
PostPosted: Fri Oct 30, 2026 8:52 am
That is completely awesome Greg! :mrgreen:
PostPosted: Fri Oct 30, 2026 11:19 am
Yeah, what a weekend. Nice.
