| About to Make the Switch To EFI - Grocery List https://slantsix.org/forum/viewtopic.php?t=23886 |
Page 9 of 9 |
| Author: | Sam Powell [ Sun Feb 17, 2013 2:40 pm ] |
Wow. Thanks for the heads up. Keep us informed. It seems there is a fine line between making it water proof and sealing up so well condensation gets trapped and you are back in trouble again. Sam |
| Author: | Supercharged SL6 [ Tue Feb 19, 2013 6:43 pm ] |
Thats why I mounted mine inside my car, it fit nicely inside my glove box it didn't look like it would hold up in the weather up here in the northeast |
| Author: | Greg Ondayko [ Thu Feb 26, 2015 3:57 pm ] |
| Post subject: | 2-26-15 Relay Board and MPG Tuning Update |
Quote: Hello Folks,
I got a New Relay board installed quite a while back.. i thought It was going bad again.. but this time It was actually A Bad Bad Spark plug wire grounding against the Inner Wheel Well.just a quick update.. About 3 weeks ago It was very Rainy around these parts.. And I drove from work to the bank to ca$h a check. I noticed the car was running very rich and very rough... After I come out of the bank I cannot start the car.. - Thought I might have flooded it etc.. kept trying and it just would not start... So I had welding Class that Night.. Could not wait around... Walked 4 Miles Home in the rain.. got my welding gear and my truck and went to class.. I stopped back Later that Night with a new coil and tools... - I disconnected the Power to the injectors and Still nothing(to Prevent Flooding) - Swapped to a known Good coil - still nothing.. had to get it towed.. First Time in 16 years of driving I have ever had anything towed Got It home and Finally came to the realization that the relay bord was not as weather proof as Diyautotune might have you believe it to be. ![]() ![]() ![]() ![]() All the Connectros and relays etc were good but the PCB had issues... So a new one was ordered.. I may need to relocate it under the Hood and I am going to put a top on it - Working on that when I return from the Banquet.. Car is up and running again.. (remember this is my daily driver) It has over 206,000 Miles on it and Probably 30,000 Miles / 4.5 Years on Megasquirt.. New Relay board is installed and No problems yet.. Daily transportation again working. Still Need to make that cover for it. Greg When I installed the second relay board I sprayed a Liberal amount of Conformal coating on both sides of the PCB before installing.. so that Should Help alot in weatherproofing it from the Harsh Salty environment that I drive in sometimes. I also did quite a bit of re-tuning on my .msq File for this car. I started out with a REQ_FUEL value of 11.4.. I has been that way since 2008 or so when I did the original install.. but after watching these videos I had a greater awareness and sensibility on how to use tunerstudio to get the results that I desired... Better MPG, Better Cranking to run transition( there was too much Cranking Pulse) and Enrichment values etc.. So instead of Tuning My cells in the fuel map - those were fairly good in my opinion.. I just leaned out the REQ fuel# by 0.1 increments until I settled in on 10.6.. This would in essence Lean the Entire Fuel map... not just a cell or 2.. It has been Joyful. I just Completed a Round trip to The Slant 6 banquet in Pigeon Forge TN from Pittsburgh in the Beige Beast.. By My GPS Mileage and Tank Fill ups.. Different Pumps along the trip of course.. I got a Best of 28 MPG, and a worst of 16.7 MPG.. for an average of 21.5 MPG for my 1000 Mile Trip and MPG Test. Fill Up#1 17.78MPG Combined Suburban / Highway Fill Up#2 22.44MPG Mostly Highway with mountains and a few Traffic Lights Fill Up#3 23.3MPG Mostly Descending Highway Elevation with a Few Suburban Traffic Lights Fill Up #4 20.73MPG All Highway Ascending Elevation and Above 75MPH Fill Up #5 28.0MPG Lights and slower Mountain Driving Due to Ice and poor Road conditions. Fill Up #6 16.73MPG Highway Driving Mostly Above 75MPH and 2 Days of Normal Commuting At home. The Highway#'s are above 20 and that includes some steep mountain grades in this trip.. The Flat highway driving from WV to Tennessee (downhill) in elevation mostly is 23.3 at about 75+ MPH in overdrive with a 3.21 Rear Axle Ratio. Long Live Megasquirt and the ability to tune it yourself. Greg |
| Author: | Reed [ Thu Feb 26, 2015 4:11 pm ] |
Those are some impressive results! Keep up the good work. |
| Author: | Greg Ondayko [ Sun Mar 19, 2017 4:46 pm ] |
| Post subject: | 3-19-17 Megasquirt functionality and component repair update |
Hi Guys, Just a quick update on the car and megasquirt.. I did the original install in 2008 and this is my daily commuter car to work etc. It gets driven in the rain, sun, salt etc. Tuesday I drove it to work, went out to drive home tues. evening and it would crank but not fire.. cold efi cars with all the enrichment built inti the map tend to flood easily.. so thats what happned. I dragged the car home, replced the coil, plugs and fuel pump.. all things i felt needed done anyway on a 229,000 daily driver. Relpacing all of those components did not get the car running correctly or easily. So i pulled the distrubitor. The dist. Is a very old 1960-1963 unit that had a pertronix unit installed in place of the points. The dist. was conveted to trigger an efi setup by rich nedbal at mopar engines west. I bought it with other efi slant stuff in a bulk buy years ago. I had always suspected that the dist. Rotor tip to trigger relationship was out of phase on this unit.. and it was. The reason i had to pull the dist ened up being a 50+ year old chrysler nylon gear that had lost teeth. So i decided to fix the phase issues. I did this by cutting a big window into an old spare cap. I windowed around the #1 terminal post as much as possible. I found that the old advance plate that the vacuum pod used to pull on was waaay too advanced for my application. I retarded the plate and put a few small welds on it to lock it dow. I reset the airgap on the pertronix unit and also installed a new dorman nylon gear. I redrilled the holes in the gear as it would have been on the original chrysler part as well as shim the end play of the shaft to a minimial amount of up and down movement. The windowed dist cap is also helpful in finding the correct timing on the slant when you stab the dist. back in the car. The car fired up on the 2nd crank! And once i got the timing and trigger offset dialed in it was running super smooth! Too bad i had to have the car quit on me to endeavor to correct this problem. Hopefully i will have the car running with megasquirt for another 10 years. Greg |
| Author: | Dart270 [ Mon Mar 20, 2017 5:34 am ] |
Very nice work and nice report, Greg. Glad the Slanted car and MS-EFI have been serving you well, and now will be even better... Lou |
| Author: | Dartman63 [ Tue Apr 04, 2017 2:34 pm ] |
Greg, I just read this entire thread at work, and all I can say is WOW. I'm glad to see/witness a success story with MS on a slant. Especially so close to me (located in SoMD). I'm hopeful that in the coming months I'll be able to finally here my 63 Dart 170 running with MS3X. I'm planning on using most of the information you've provided along with Matt (who has helped me in the past with understanding MS) to get my /6. Thank you so much for sharing all of the story with us here. Hopefully when I get my car running I can join you on that 1000 mile trip to the slant Banquet. Jay |
| Author: | Rick Covalt [ Tue Apr 04, 2017 5:03 pm ] |
Jay, why not try and make it up to the Slant 6 race in May at Hagerstown and you can meet these folks in person! Consider this your personal invite. Rick |
| Author: | Greg Ondayko [ Wed Apr 05, 2017 5:56 pm ] |
Sounds good Jay.. thats what its all about. Lou has 2 mesquirted slants with way more miles on them etc, If yoy come to the mason dixon race in may to race or specate /bench race than you might just see at least 2 megasquirted cars in person.. Hint... one runs 11's. Greg |
| Author: | Dart270 [ Thu Apr 06, 2017 3:23 am ] |
One of my MS cars will be there, and with some luck running 12s, or at least low 13s. Lou |
| Author: | bob pekny [ Fri Apr 21, 2017 7:30 pm ] |
Greg, I am in the planning stages of a ms2 install in an 85 Dodge pickup. Thanks for all your info over the years. After reading about your troubles with the relay board I am wondering if I ought to go ahead and mount it in the cab along with the ms2 box. It will make the wires a bit harder to run but it ought to eliminate future moisture problems. I would rather just do this once. What do you think? Bob Pekny |
| Author: | Matt Cramer [ Mon Apr 24, 2017 1:53 pm ] |
No reason not to put the relay board inside the passenger compartment as long as you can find a space to put it. |
| Author: | Greg Ondayko [ Wed Aug 16, 2017 5:48 pm ] |
If its going to be a fair weather truck... sunny days, car shows etc. Underhood will be fine. The second time around i did coat the board with conformal spray coating.. it has been fine since. Of course this was my daily driver from 2008 until a month ago. If you plan on using it like a real car then find an interior or wrathertite soultion. Greg |
| Author: | Greg Ondayko [ Wed Aug 24, 2022 4:17 pm ] |
| Post subject: | Re: About to Make the Switch To EFI - Grocery List |
Accel Enrichment Algorithm was also Much improved! Finally got rid of that Accel stumble / flat spot, Used the same old settings that were imported from my pre firmware upgrade, and Just edited a few bins as well as clicked a slider around until it felt like a good carbby pump shot! WHOO HOO! |
| Page 9 of 9 | All times are UTC-07:00 |
