| PowerPipe-DC (True Flow Header Design) https://slantsix.org/forum/viewtopic.php?t=39043 |
Page 9 of 12 |
| Author: | Mister Twister [ Sat May 22, 2010 3:57 am ] |
Quote: any chance for dyno numbers to compare to the power pipe or PP-DC?
We started with a direct replacement with larger than stock intermediate pipe of 3" with an exit of 2 1/4" This unit was small gain over stock on dyno. Stock manifold here.![]() http://www.stormcomm.net/dyno.mov This is the PowerPipe-SC Look how much quicker the torque comes in and the steady climb and fall. ![]() Hope this helps with your question. This was the only one put on the dyno so far . I feel the DC and the True Flow design would be better yet Don |
| Author: | Evilsizer [ Sat May 22, 2010 5:38 am ] |
so is there any chance you will have numbers for the DC and true flow in the future? on the fence about which one... |
| Author: | Aggressive Ted [ Sat May 22, 2010 11:56 am ] |
| Post subject: | Max torque from headers |
These dyno charts are very helpful. I am looking forward to the next two (DC vs True flow) as well. Did you say you had the long hookers charted as well and the Clifford shorties? This would make a heck of a collection of dyno charts and a good Engine FAQ sticky. I am looking for what Doc was talking about in another post earlier this week, lots of torque at lower rpms vs max HP. My engine is built for more torque so I am looking for the best exhaust to make the most torque. Thanks, |
| Author: | Mister Twister [ Mon May 31, 2010 8:56 am ] |
Quote: Please get a sound recording of the x+y pipe when installed.
Here you go old blue. I will have more soon, going down the road a bit, revving up!! The in car we have is all motor no exhaust sound/drone at all. http://www.youtube.com/watch?v=6oRVNd28h-A That was no good without pics!! 1st gear ride in TwIsTeR http://www.youtube.com/watch?v=kq9bjeQ4fpo |
| Author: | Mister Twister [ Mon May 31, 2010 9:29 am ] |
Quote: so is there any chance you will have numbers for the DC and true flow in the future?
Yes we will be testing them!! PowerPipe-DC-PF-TF on the fence about which one... |
| Author: | oldblue [ Mon May 31, 2010 9:57 am ] |
Thanks for the sound bite.Sounds very good.I like the open sound.What cam are you running? |
| Author: | Mister Twister [ Mon May 31, 2010 3:15 pm ] |
Quote: If the muffler has sufficient flow capacity a Y-pipe makes just as much power as duals with an X-pipe. It also weighs less and costs less.
Sufficient flow like a straight through muffler design? I will be testing the difference soon X plus Y and Y by itself. Yes it's a little heaver but I run two tail pipes as well. I will also save the weight and money for sure if it's not better.
| Author: | Mister Twister [ Tue Jun 01, 2010 2:50 am ] |
Quote: The idea with both X and Y pipes is to combine pulses. I don't expect a benefit to using both together myself.
Thanks for your input on this Matt. Sometimes things just don't add up. I hope this is not one. |
| Author: | Mister Twister [ Tue Jun 01, 2010 3:25 am ] |
Quote: Thanks for the sound bite.Sounds very good.I like the open sound.What cam are you running?
No problem, glad you like the sound! This was the first two chamber muffler I put together last week. I keep riding around waiting for drone. Up to 3500rpm steady running still no drone |
| Author: | gl/6 [ Tue Jun 01, 2010 4:27 pm ] |
I very, very, likely will buy a set simply based on how this twister Dude has listened to members. Deep inside we all respect sweat and fairness. Time to take that info and sum it up. Too many cooks spoil the broth. God Speed twister. GL |
| Author: | Rug_Trucker [ Sat Jun 05, 2010 6:20 am ] |
Got my popcorn. |
| Author: | Mister Twister [ Sat Jun 12, 2010 2:38 am ] |
Quote: Got my popcorn.
Sitting back and enjoying the show huh, |
| Author: | Mister Twister [ Sat Jun 12, 2010 2:44 am ] |
Quote: I very, very, likely will buy a set simply based on how this twister Dude has listened to members. Deep inside we all respect sweat and fairness.
Thank you gl/6 a little bit of this and that in the soup and it should be tasting pretty good by now. Where is the bread Time to take that info and sum it up. Too many cooks spoil the broth. God Speed twister. GL |
| Author: | Mister Twister [ Sat Jun 12, 2010 2:50 am ] |
Spoke with Charlie on the phone |
| Author: | Mister Twister [ Sun Jun 20, 2010 10:12 am ] |
We picked up the 65 Valiant from Charlies last week. The header build will start this week for the early A-Bodies. The car is at the shop 225 removed and the 170 going in soon. Flat towed er all the way to Bradenton!! The 170 is a 1964 block. Thanks again Charlie! More up dates as we progress. |
| Page 9 of 12 | All times are UTC-07:00 |
