| 1964 Dart Grüne Hölle Road Course AutoX Car IRWIN PA https://slantsix.org/forum/viewtopic.php?t=60536 |
Page 9 of 40 |
| Author: | Badvert65 [ Fri May 17, 2019 2:12 pm ] |
| Post subject: | Re: 1964 Dart Grüne Hölle Road Course AutoX Car IRWIN PA |
What side are the outlets for your radiator? |
| Author: | Greg Ondayko [ Fri May 17, 2019 2:35 pm ] |
Same as stock. Top side on drivers. Bottom outlet on passenger side. Greg |
| Author: | Rick Covalt [ Fri May 17, 2019 3:13 pm ] |
Yes it is 1.75 on the radiator end. It is almost a perfect fit, molded hose, made for this swap. I think I cut 1 or 2" off the end that goes to the water pump. Other than that it is a bolt in. Hose is for 1982-91 Camaro, 305 engine W/O AC Pictures on page 44 of my Valiant build if you want to look at them. Also a Bronco upper hose that worked great too. |
| Author: | Greg Ondayko [ Fri May 17, 2019 3:17 pm ] |
Cool. Next time I will keep that in mind. I knew there were hoses that would probably work out there.. but i did want to spend the time to research and find them. Greg |
| Author: | drgonzo [ Fri May 17, 2019 6:28 pm ] |
That's looking wicked. I love the look of road race cars. |
| Author: | Dart270 [ Sat May 18, 2019 3:16 am ] |
Sinister indeed. Can't wait to have 2 green 64 Darts with Slant 6s on a road course together. Lou |
| Author: | sixinthehead [ Sat May 18, 2019 4:41 am ] |
Lou, just tell everyone that his used to be like yours until you blew a couple of his doors off |
| Author: | Greg Ondayko [ Sat May 18, 2019 5:40 am ] |
He he.. that would certinally happen! Greg |
| Author: | Dart270 [ Sun May 19, 2019 2:34 am ] |
I almost made a comment about Greg's not having the correct number of doors... I look forward to having a battle of the door blowing (FOUR DOORS VS. THE WORLD) on some kind of twisty course. Lou |
| Author: | Dart270 [ Mon Jul 08, 2019 4:24 am ] |
Nice progress. I also needed 0.1" spacer plates on the 68 Dart. Lou |
| Author: | Greg Ondayko [ Mon Jul 08, 2019 6:10 am ] |
Got all of the Links Installed last night. Later today or tomorrow I will place the rear end in the car and connect everything up and then find where the upper link brackets fall on the housing. The old transmission that I got on craigslist is sure coming in handy now! Greg |
| Page 9 of 40 | All times are UTC-07:00 |
