| Covalt - "Project 65 Valiant" https://slantsix.org/forum/viewtopic.php?t=35632 |
Page 90 of 128 |
| Author: | Rick Covalt [ Sat Dec 14, 2019 5:45 am ] |
| Post subject: | Re: Covalt - "Project 65 Valiant" |
Goals for the coming 2020 season will be to be consistently in the 12's. I will lose about 90-100 pound in weight and still leave the steel hood in place. Carry 8 gallons less gas- 50#, New race seat and aluminum brackets 17# Remove Passenger door panel, glass and winder, both rear side windows- 26#. Should be able to get into the 12.80's or better with some tuning. Just going to enjoy having a nice fast car for next year, and maybe for 2021 I will debut the 4 speed after all? |
| Author: | Rob Simmons [ Sat Dec 14, 2019 6:24 am ] |
Sounds like a good plan Rick. |
| Author: | Rick Covalt [ Sat Dec 14, 2019 12:05 pm ] |
Just installed the right side Lexan window! Man that is some tough stuff! |
| Author: | slantzilla [ Sat Dec 14, 2019 12:21 pm ] |
Be careful what you use writing your numbers on it. I have some fancy dial in marker stuff and I usually have to buff it off. |
| Author: | Rick Covalt [ Sat Dec 14, 2019 12:49 pm ] |
I think I'm going try having the local sign guy who does wraps and stuff cover the rear side glasses in clear vinyl. I will ask him if that would work or not. He is a drag racer too so he will know. |
| Author: | Dart270 [ Sat Dec 14, 2019 1:45 pm ] |
Sounds like a great plan, Rick. A man of action... Lou |
| Author: | Rick Covalt [ Sat Dec 14, 2019 2:14 pm ] |
Got the transmission pan off and the valve body out this afternoon. Going to replace the selector shaft seal which has been leaking all year! I finally had an engine in that did not leak anywhere and the transmission leaked all the time!!! If you remember I had this valve body in and out 4 or 5 times until I found that the problem was the little nub on one of the shuttles was worn a bit. I was told to place a small washer behind it and that fixed it. However the washer is just loose in there, and while it has not given me any trouble, while it is out I am going to tack weld it to the end plate. More to come! |
| Author: | Rick Covalt [ Wed Dec 25, 2019 11:27 am ] |
Well! Christmas time is here and a very special employer (Thanks son) and my other 3 boys and wife came together and somehow I am going to end up with a new fiberglass hood and trunk lid!!! If my math is close I will lose about 160# or so. The Wallace calculator says that a 12.95 ET at my weight and losing 160# should be in the 12.7x ish range. Right where I wanted to be some day!! |
| Author: | Greg Ondayko [ Wed Dec 25, 2019 1:42 pm ] |
See.... puttin in the extra hours at RC engines wasnt so bad! Merry christmas Covalt Clan. Greg |
| Author: | Rob Simmons [ Thu Dec 26, 2019 6:43 am ] |
That’s awesome Rick!! Very cool! |
| Author: | Dart270 [ Thu Dec 26, 2019 11:48 am ] |
Perfectamundo... Lou |
| Author: | slantzilla [ Thu Dec 26, 2019 11:49 am ] |
Geez Rick, you're forcing me to get a glass decklid for my junk now. |
| Author: | Rick Covalt [ Thu Dec 26, 2019 2:17 pm ] |
Quote: Geez Rick, you're forcing me to get a glass decklid for my junk now.
Zilla, I'm pretty sure you are the one that said this is a never ending thing! Right??With 12.70's as a new goal for 2020, that really isn't that far from 12.50!! |
| Author: | slantzilla [ Thu Dec 26, 2019 2:22 pm ] |
Then 12:30, then 12:0s.......... |
| Author: | Rick Covalt [ Fri Dec 27, 2019 6:52 am ] |
3 lexan windows, removed door panels and winder = 25# gone Attachment: IMG_0069.JPG [ 54.77 KiB | Viewed 5506 times ] |
| Page 90 of 128 | All times are UTC-07:00 |
