| PowerPipe-DC (True Flow Header Design) https://slantsix.org/forum/viewtopic.php?t=39043 |
Page 10 of 12 |
| Author: | Mister Twister [ Sat Jun 26, 2010 11:17 am ] |
The 170 is in the car!! Started some measurements today on the True Flow Headers for the early A-Bodies again I will be putting in the power steering box in for the build just checking the difference for now. If they will work with this intake, they should just about work with any of them don't you think |
| Author: | Joshie225 [ Sat Jun 26, 2010 11:24 am ] |
As I stated before I need headers for a 170 in an early A. If you could build them with 1 5/8" pipe to 2 1/2" collectors and clear the stock clutch linkage that would be ideal. I'm using the same Clifford manifold as pictured. |
| Author: | Dart270 [ Sun Jun 27, 2010 9:25 pm ] |
Yes, if it will clear that intake, it should fit about anything. The only induction I might worry about are Webers, and very few people use those. Lou |
| Author: | Mister Twister [ Wed Jun 30, 2010 3:57 pm ] |
Quote: As I stated before I need headers for a 170 in an early A. If you could build them with 1 5/8" pipe to 2 1/2" collectors and clear the stock clutch linkage that would be ideal. I'm using the same Clifford manifold as pictured.
Hello Joshua. I do have a standard in one of my Dusters this will be out soon for a clutch. How close is the Z bar and rod connection tho, I don't know. We can check with Charlie and see if he might have them from this car or another. I will increase the primary pipe size as the design is calculated to make sure they have the room to increase. This combination will be tight |
| Author: | Joshie225 [ Wed Jun 30, 2010 4:20 pm ] |
Yeah, my project is going to be more difficult than usual. If the pipes don't make it through with a Z-bar and linkage in place I'll go with a hydraulic clutch. I'd like to stay with the mechanical clutch linkage as I already own it, but I'll do what it takes ($$$) to go fast. |
| Author: | Mister Twister [ Fri Jul 02, 2010 7:45 am ] |
Quote: Yes, if it will clear that intake, it should fit about anything. The only induction I might worry about are Webers, and very few people use those.
Hay Lou, you had me looking through the gallery found a couple pics of the weber set up. I see that would be a different animal for exhaust. Allot of options I see. Is that what they mean by down draft? I see this as up draft. Lou
| Author: | maxracer21 [ Fri Jul 02, 2010 8:30 am ] |
That would be side drafts...........MaX |
| Author: | Mister Twister [ Fri Jul 02, 2010 8:48 am ] |
Quote: That would be side drafts...........MaX and this one is?These remind me of my old motor cycle carb set up!! |
| Author: | maxracer21 [ Fri Jul 02, 2010 9:54 am ] |
man those look great..........trying to find some SU's myself............got the manifold. Need some 1"3/4's. |
| Author: | 65 dartman [ Fri Jul 02, 2010 10:18 am ] |
Quote: Quote: That would be side drafts...........MaX and this one is?These remind me of my old motor cycle carb set up!! |
| Author: | Mister Twister [ Fri Jul 02, 2010 10:48 am ] |
Wich one do you haveMaX? 1 3/4'S!! |
| Author: | maxracer21 [ Fri Jul 02, 2010 12:45 pm ] |
Right O............looking looking |
| Author: | Mister Twister [ Sun Jul 04, 2010 7:34 am ] |
New or used? I work closley with a MG/European resto company here and he has allot of pull-offs that function fine. |
| Author: | maxracer21 [ Sun Jul 04, 2010 8:31 am ] |
Thank you ....................I purchased a Warneford design manifold w/long runners.....3 X 1 3/4 will be the first test on the salt car. Might even take three 2 1/8 SU's . some sort of linkage would be important too. Gotta try every option we can and dyno them. You have played a big part already and are appreciated. At least you can think out of that BOX thanks a bunch MaX What gets me is the old NASCAR boys were faster than we are today. What are we missing? Reseach, research like to know what they were doing. |
| Author: | Mister Twister [ Tue Jul 06, 2010 8:05 am ] |
Hello charlie hope all is well. I see allot of people running manual. Some pics of that area would be nice and help allot till I get some linkage. |
| Page 10 of 12 | All times are UTC-07:00 |
