It is currently Sat Nov 28, 2026 10:41 pm
Post new topic  Reply to topic  [ 705 posts ]  Go to page Previous 1 … 8 9 10 11 12 … 47 Next
 Post subject: Lexan fixed,... sorta...
PostPosted: Wed Jun 01, 2011 9:15 am
http://img849.imageshack.us/img849/8494/gedc0068.jpg
Here's the yellowed rear piece layed over the top of the polished front piece. It looks clear sitting there in the garage, but not sure what it will look like trying to see through it out in the sun looking for that "last amber" :lol:
PostPosted: Wed Jun 01, 2011 9:35 pm
Looks pretty good! If nothing else, those windows will save you a TON of time when cutting new ones. Making the first ones to fit is a lotta nitpicky work.
PostPosted: Thu Jun 02, 2011 7:55 am
That's true! :D
I owe Norm Foster a debt of gratitude for doing most of the ground work on these cool race cars for me to enjoy! :wink:
First the GodsRods Duster II and next the Challenger! :shock:
Hey Norm, you can drive either one of them any time you want! :D
PostPosted: Thu Jun 02, 2011 8:41 pm
That'll be cool trick if you get both running and Norm ends up driving one...
We'll miss you in Kearney!!
PostPosted: Fri Jun 10, 2011 12:54 pm
...if you get both running...
Just caught that... Yeah, hopefully some day... :roll: :lol:
PostPosted: Sat Jun 11, 2011 4:42 pm
Rob, That lexan sure does look a lot different than the last time I saw it. I never thought it would clean up that much.
Train like you fight anything less is a waste of time.
PostPosted: Mon Jun 13, 2011 4:33 am
Yeah, I was pretty doubtful at first.
The first couple steps sanded off all the yellow haze and then the following steps just kept polishing it up. Hopefully it will work out okay.
The boys are out of school now and we just finished our home swim meet this weekend, so I'm hoping we will have more time to get over to the garage and make some better progress.
PostPosted: Wed Jun 15, 2011 7:12 am
In the fine "GodsRods Tradition" from back in 2003...
http://www.slantsix.org/forum/viewtopic.php?t=5217
36 days until the drag race in Elk Creek, VA... Will the GodsRods Duster II make it there or not...? Not sure about the car, but I'm going regardless! :lol:
PostPosted: Mon Jun 27, 2011 9:04 am
Andrew and I spent some time at the garage the other day. :D
1. Rear brake hard line is replaced
2. Front brake hard line with Line Loc is installed
3. Rear lexan windshield is polished
Most of the time at the garage was spent installing a yard spigot so we have water and continuing to clean up the property. One of the three big oak trees got hit by lightning last week, so there were bark and limbs blasted all over the place (not sure the tree will survive much longer :( ). Clean up continues on the huge pile of debris from a tornado a couple years ago. They just piled everything at the bottom of the hill, so I try to make a dump run every few weeks to eventually get it all cleaned up.
The rest of the weekend was spent cleaning out the garage at the house so Angie can park the Suburban in there again. We still had to put away all the camping gear from Chase's birthday trip last weekend. It rained a lot, so things were brought home kinda wet.
After that we jumped back on the basement project. Finished up some tile in the bathroom and hung the mirror, towel racks, etc. The plumber didn't seal the sink drain, so it leaks. :roll:
My poor old back and knees just ain't what they used to be. :roll: I feel like a car that has had the warranty expire. Everything has started to fall apart! :shock:
I was proud of making a little progress on the Duster until I counted the days remaining until Elk Creek... We need to get to some serious wrenching! :shock: :lol:
 Post subject: "Mad Thrash" Update
PostPosted: Mon Jun 27, 2011 12:08 pm
1. [X] Replace brake line to rear of car
2. [/] Either swap in the 8 3/4 (3.91 Sure Grip) and driveshaft from Street Duster or fix the leaky axle seal on the Ford 8" (4.56 Mini Spool) and get another driveshaft (May be able to use the current driveshaft with the 8" by simply swapping the rear U-Joint! :D )
3. [/] Either swap in the disc brakes from Street Duster or continue to use the SBP drum brakes - Leaning toward the heavier, but safer discs for next year / Will use the SBP Drums at least for Elk Creek / This season
4. [_] Install fuel cell, lines, pump, etc.
5. [_] Install wiring and gauges (ignition, tach, water, oil...)
6. [/] Buy and install a carb / linkage / gas pedal
7. [_] Install radiator
8. [_] Buy and install trans cooler and lines
9. [_] Install seats and harnesses
10. [/] Polish and reinstall or buy new lexan for both windshields
11. [_] Cover a hole in the driver side floorboard
12. [_] Paint floors and roll bar
13. [_] Probably another dozen things I haven't thought of yet! :lol:
Stuff in BOLD is an update since last time. The / means the task is only partially completed. Once the task is completed it will change to X.
PostPosted: Tue Jun 28, 2011 7:31 am
I spent the evening at the garage yesterday.
I started by installing a pulley on the crank dampener to run the water pump and then started looking at the fuel cell, driveshaft loop... I'm realizing more and more that, in addition to OCD, I've got ADD too! :shock: :lol:
I chased my tail in circles for a little while and realized that the utter chaos in the garage was the main (okay, just one of 'em) culprit to my confusion. So, I spent the evening cleaning and organizing the garage! :shock:
I moved shelves around and cleaned up a lot. The spiders don't like me right now. :lol: I cleared a spot for my workbench and toolbox finally! :shock: Hopefully this evening I will have Andrew help me move them over there. That alone will make a huge difference in how productive I am... (yeah , right :roll: :lol: )
PostPosted: Tue Jun 28, 2011 7:50 am
Go, Rob, go! Organization makes a huge difference in how I work and plan projects...
PostPosted: Tue Jun 28, 2011 10:31 am
Poser
Rob - put that(organize garage) on your list and put an X by it. One step closer......
 Post subject: Re: "Mad Thrash" Update
PostPosted: Tue Jun 28, 2011 10:48 am
2. [_] Either swap in the 8 3/4 (3.91 Sure Grip) and driveshaft from Street Duster or fix the leaky axle seal on the Ford 8" (4.56 Mini Spool) and get another driveshaft
3. [/] Either swap in the disc brakes from Street Duster or continue to use the SBP drum brakes - Will use the SBP Drums at least for Elk Creek
10. [/] Polish and reinstall lexan windshields
13. [X] Install Line Loc
14. [_] Reinstall Driveshaft Loop
15. [X] Clean and organize garage for better productivity/safety :D
16. [_] Install water pump pulley
17. [_] Decide whether to run an alternator or get a battery charger
18. [_] Probably another dozen things I haven't thought of yet! :lol:
PostPosted: Tue Jun 28, 2011 4:59 pm
Not seeing too many X's there Rob. :lol:
IF I don't have to work Satiddy I want to get down and try to get the red pig straightened out and take it to 41 for some testing. :D
