| Rob's 1981 Dodge Challenger https://slantsix.org/forum/viewtopic.php?t=46322 |
Page 10 of 61 |
| Author: | Rob Simmons [ Mon Apr 29, 2013 12:40 pm ] |
Quote: Quote: Angie gave me the "go ahead" to make plans to attend most of the East Coast races this year.
That's good news!Apparently Cookies wife didn't tell him the same thing. Rick If only some of her enthusiasm would rub off on poor ole Cookie about dem Slant 6 cars he's got... |
| Author: | Rob Simmons [ Tue May 28, 2013 6:47 pm ] |
I showed the Challenger to my new fabricator buddy this evening... That's all. Maybe I'll get around to installing the oil pan soon... Then I can put the engine in the car!... Maybe... |
| Author: | Rob Simmons [ Tue Jul 02, 2013 5:55 am ] |
Some more specifics on the car: Good stuff: 100 inch wheelbase which is good for a car that size. A similar Charger is only 98 4 wheel lite weight disc brakes Alum center section 8 3/4 (very rare) 4.56 gears with a spool High Quality forged alum wheels 10.5x31x15W rear tires 26x4.5 front tires 2050 lbs without driver running the Slant 6 non adj Coil over shocks all 4 corners Ladder bar 2x3 Main rails Mustang II style front suspension with aftermarket Upper and lower control arms Manual rack and pinion HD strut rods run to front Alum radiator with fan Alcohol fuel cell Crossover Delay box Transbrake 4800 stall converter Electric shifter with RPM switch MSD 6AL box with 2 step Nice Lexan well mounted Nice interior alum work Good paint w/Mopar graphic decals Unique Mopar (only one at the track) Not so good stuff: Engine has to be gone through Gap between the back of the hood and base of windshield about 4x10 inches in the center Shocks are not adjustable for Jounce and rebound Bottom line is that the cage needs a lot of work to be certified for 9.99 or faster But Norm ran the car in all of the Slant 6 stuff with no issues You never know when they will say something about the window net or side bars even in a 12 sec car. No window net. NHRA requires any car with a ROLL CAGE ( NOT ROLL BAR) to have a window net Main roll cage hoop is 1.75 inches - Legal Door side bars are curved and Low - Illegal All of the rear bars off the main hoop are 1.5 " - Illegal A nice V8 could be fitted and the car would go in the 9's on pump gas, but you would have to fix the chassis. |
| Author: | Dart270 [ Thu Jul 04, 2013 8:45 am ] |
Sounds promising, Rob. Next question is why did that happen? Worth a try to just replace that one, or maybe all the mains while you're at it. Lou |
| Author: | Fopar [ Thu Jul 04, 2013 9:18 am ] |
I would mike the crank for sure! Richard |
| Author: | DusterIdiot [ Thu Jul 04, 2013 7:41 pm ] |
| Post subject: | Lol... |
You know , if you put 4 years of apprenticeship in doing stuff like that, they will actually pay you and call you a journeyman.... -D.Idiot |
| Author: | Rob Simmons [ Thu Jul 04, 2013 7:46 pm ] |
Now THAT's funny! I did have fun doing it though. I needed some "car therapy"! |
| Author: | Dart270 [ Fri Jul 05, 2013 8:24 am ] |
Make sure the baffles allow the oil to get back into the pan sump. I spend a lot of time angling them down and having a good sized hole in the middle. Lou |
| Author: | Rob Simmons [ Fri Jul 05, 2013 1:21 pm ] |
What!? Them dozen donut holes I dun drilled in it ain't good enough...? I s'pose I could connect them 6 in the middle into 1 real big one... Does a deep rear sump drag pan like this even really NEED that kinda baffle? It certainly isn't a road course car or anything... The last thing I want to do is inadvertently starve the engine for oil thinking I'm doing a "good" thing by adding a baffle... Sumbudy educate me b'fore I do sumthin' even more dumber than what I usually do! |
| Author: | sandy in BC [ Fri Jul 05, 2013 4:45 pm ] |
its baffling really......... <,,,,,,,,,baffed again.......> /baff check?/ |
| Author: | Dart270 [ Sat Jul 06, 2013 3:07 am ] |
I would say maybe a 1.5" shelf around the rim is the most you would need, or just front and back shelves. Make sure the pickup is touching the floor and near the middle of the sump or about 1" toward the rear from center. Lou |
| Author: | Dart270 [ Sat Jul 06, 2013 3:08 am ] |
Also, make sure you have a hole for the dipstick. I drove around for 3-4 yrs in my 68 Dart with no dipstick because I forgot to mark/drill that particular hole. Looks like you have that covered. Lou |
| Author: | Rob Simmons [ Sat Jul 06, 2013 5:00 am ] |
I'll connect the 6 middle holes into one big one then. The pickup is about 1/4" from the bottom of the pan the way Norm had it. I've got the dipstick thing covered TWICE! There's the original dipstick tube in the side of the pan (that Norm just had blocked off - No dipstick) The new engine already has a dipstick, but it points to a spot further toward the front of the pan - not into the deep sump... What ever shall I do!? Should I run two dipsticks (Shut up Sandy & 'Zilla! And how high should the oil level be? I need to call Norm and ask what the capacity on this pan is... I'll be swapping the Howard Davis head, RAS roller rockers and Smith Brothers push rods on as well. Might as well put all the goodies in one basket. |
| Page 10 of 61 | All times are UTC-07:00 |
