It is currently Tue Jul 14, 2026 3:50 pm
Post new topic  Reply to topic  [ 143 posts ]  Go to page Previous 16 7 8 9 10
PostPosted: Fri May 07, 2021 5:24 pm
https://youtu.be/kIGz2e6al00 just found this from a local videographer!
PostPosted: Tue Oct 04, 2022 5:46 am
busy 2yrs with family stuff! only made last weekend of this season, great to be behind the wheel only for methanol injection signal hose popped off and i broke #1 rod and killed the block! surgery has begun! one pushrod popped out so hoping cam and head is good! https://scontent-lga3-1.xx.fbcdn.net/v/ ... e=63411C5B
PostPosted: Tue Oct 04, 2022 5:48 am
Sorry to Hear it.
You are doing some wicked stuff up there in the Nordlands!
Best of luck on the reconstructive surgery.
PostPosted: Tue Oct 04, 2022 5:53 am
thanks! car was running great! have to find a more secure way of checking methanol system! can`t afford race fuel up here! hard to turn the power back to match the fuel! haha!
PostPosted: Tue Oct 04, 2022 9:41 am
Well,... When ya push the limits... You usually find 'em... :wink:
Great job representing the Slant 6 community!!
PostPosted: Tue Oct 04, 2022 2:26 pm
That sucks Terry. Good luck getting it all back together.
What happened? Did it flood and hydraulic the cylinder?
PostPosted: Wed Oct 05, 2022 10:46 am
no, i was leaning the carb`s to see if i could get 11.0 air/fuel, the hose on the intake was knocked off or popped off! with no vac to the switch there was no menthanol injected and she doesn`t like that! i had the power wire come off once but it only smoked a few pistons! the leaner mix detentated #1 so bad that the piston broke the bearing spun and one rod bolt failed then the rod broke into three peices! has anybody ever run a n2o throttle switch as a backup to activate the methanol pump at wide open throttle?
PostPosted: Wed Oct 05, 2022 3:06 pm
https://live.staticflickr.com/65535/524 ... b358_w.jpg https://live.staticflickr.com/65535/524 ... e645_w.jpg https://live.staticflickr.com/65535/524 ... 07db_w.jpg
