| Terry Littlejohn's Dusters https://slantsix.org/forum/viewtopic.php?t=5432 |
Page 10 of 10 |
| Author: | terrylittlejohn [ Fri May 07, 2021 5:24 pm ] |
| Post subject: | Re: Terry Littlejohn's Dusters |
https://youtu.be/kIGz2e6al00 just found this from a local videographer! |
| Author: | terrylittlejohn [ Tue Oct 04, 2022 5:46 am ] |
busy 2yrs with family stuff! only made last weekend of this season, great to be behind the wheel only for methanol injection signal hose popped off and i broke #1 rod and killed the block! surgery has begun! one pushrod popped out so hoping cam and head is good! https://scontent-lga3-1.xx.fbcdn.net/v/ ... e=63411C5B |
| Author: | Greg Ondayko [ Tue Oct 04, 2022 5:48 am ] |
Sorry to Hear it. You are doing some wicked stuff up there in the Nordlands! Best of luck on the reconstructive surgery. Greg |
| Author: | terrylittlejohn [ Tue Oct 04, 2022 5:53 am ] |
thanks! car was running great! have to find a more secure way of checking methanol system! can`t afford race fuel up here! hard to turn the power back to match the fuel! haha! |
| Author: | Rob Simmons [ Tue Oct 04, 2022 9:41 am ] |
Well,... When ya push the limits... You usually find 'em... Great job representing the Slant 6 community!! |
| Author: | slantzilla [ Tue Oct 04, 2022 2:26 pm ] |
That sucks Terry. Good luck getting it all back together. What happened? Did it flood and hydraulic the cylinder? |
| Author: | terrylittlejohn [ Wed Oct 05, 2022 10:46 am ] |
no, i was leaning the carb`s to see if i could get 11.0 air/fuel, the hose on the intake was knocked off or popped off! with no vac to the switch there was no menthanol injected and she doesn`t like that! i had the power wire come off once but it only smoked a few pistons! the leaner mix detentated #1 so bad that the piston broke the bearing spun and one rod bolt failed then the rod broke into three peices! has anybody ever run a n2o throttle switch as a backup to activate the methanol pump at wide open throttle? |
| Author: | terrylittlejohn [ Wed Oct 05, 2022 3:06 pm ] |
https://live.staticflickr.com/65535/524 ... b358_w.jpg https://live.staticflickr.com/65535/524 ... e645_w.jpg https://live.staticflickr.com/65535/524 ... 07db_w.jpg |
| Page 10 of 10 | All times are UTC-07:00 |
