It is currently Tue Jun 09, 2026 2:01 am
Post new topic  Reply to topic  [ 1918 posts ]  Go to page Previous 195 96 97 98 99128 Next
PostPosted: Sat Jun 06, 2020 5:53 pm
"High Output", on a citation?
Yes 1981 ish. High Output V6 - 135HP :D :D
Where do you get the emblems you showed Stan?
Rick, I forget. Someone on FABO or here cast them and they are very nice.
I will look at my private messages, maybe I will find something.
PostPosted: Sat Jun 06, 2020 7:57 pm
It was FABO, but 2016!
https://www.forabodiesonly.com/mopar/th ... le.346460/
PostPosted: Sat Jun 06, 2020 8:17 pm
The X-11? We had a customer who had one. Throttle cable froze on it one winter when he started it at -15. It was No Output after that.
Good job on your weight loss. That is within a few pounds of what mine eeighs with my fat azz in it.
PostPosted: Sun Jun 28, 2020 4:17 pm
Took the car down the road for a test run, after doing all the work to it and everything worked great! Car feels really good/fast, but that could all be in my head. But losing 120# should have helped. New aluminum master cylinder works superb! Much better brakes than with the old cast iron one. I would guess this one has a smaller piston, although I can't remember.
Then on Wednesday I drove it the 3-4 miles over to Ryan's for a bit of a car show, and it ran fine. With 4.30 gears and a motor that runs 12's the temperature never got up to 160 even though I warmed it up some before I left. Didn't even turn the electric fan on till I was over 1/2 way home when I left. Thankful for a good aluminum radiator! :D :D
Now if we could just get to a race and see what this thing will do!! :D :D
PostPosted: Sun Jun 28, 2020 4:25 pm
Super work, Rick! 120 lbs is no joke and you can feel a difference. I still need to weigh the white 62 - curious...
PostPosted: Sun Jun 28, 2020 5:12 pm
Sounds Good.
What Master Cylinder did you choose?
Why don't you take it to Mason Dixon for some Test n Tune?
PostPosted: Sun Jun 28, 2020 5:55 pm
I will soon. I may take it to South Mtn Friday at the Chryslers at Carlisle
PostPosted: Sun Jun 28, 2020 5:56 pm
Sounds great Rick!
PostPosted: Sun Jun 28, 2020 5:58 pm
Well If you do that let me know I can stop By.
Supposed to be taking the Green dart to the autoX @ carlisle.. It's Friday Nite so Not sure how late it will run.
PostPosted: Sat Jul 25, 2020 4:14 am
So I finally made it out to Mason Dixon for a T&T last night. We had a little grudge race between Austin Houpt, who raced with us a couple times and myself. Austin has a nice 65 Mustang, 289 4 speed, It has a high performance engine in it with 3.50 gears.
We raced 5 times and the old Slant 6 won all 5 times. The best he could muster was a 13.66! To be fair the gears killed him on take off and he had a bad bog with the sticky tires he was running. On run number 5 he left his 9" rear or the axles in pieces inside the housing. :(
My Valiant which is basically the same as when I parked it last Fall, less 120#, ran a 13.00 @ 100.6 first round in very bad air. After a cool down of about 30 minutes and a drop in temperature to about 82 degrees(still with 90%humidity) the car ran a best ever 12.84 @ 102. I really had a great time and did feel bad for Austin. He had about 8 people come to watch his Mustang eat my Valiant alive! I sat in my lawn chair, drank water and ate chips as they worked and adjusted the Ford each run trying to catch the little lowly Slant 6
I even offered to tow his car home! That's what friends do :D :D
PostPosted: Sat Jul 25, 2020 6:44 am
WOW Rick, that's really cookin'. Congrats on the wins and making Slanters Proud.
PostPosted: Sat Jul 25, 2020 10:02 am
Good job Rick!
PostPosted: Sat Jul 25, 2020 3:11 pm
Gettum them 12's
You waynesboro boys (rick not included) like to break stuff.
PostPosted: Sat Jul 25, 2020 3:27 pm
Well done!
Those 28-spline F*rd axles really are a weak link.
PostPosted: Sat Jul 25, 2020 4:21 pm
Yep, They have a 31 spline set and a pumpkin with 3.89 gears and I'm sure he will want to go at me again! :D
Can't wait!! :D :D
