| 1964 Dodge dart 4 speed https://slantsix.org/forum/viewtopic.php?t=10385 |
Page 2 of 2 |
| Author: | Dart270 [ Wed Oct 05, 2005 6:32 am ] |
You're gettin' there! Keep up the good work. I have not heard of BB chev springs, but why not? It's just a matter of diameters, spring rate, installed height, retainer fitment... Lou |
| Author: | sixty4dartgt [ Sat Oct 29, 2005 11:47 pm ] |
| Post subject: | Broke into the 15's |
I went to the track today. I have the new head on. Here's a recap of my car: 225 - .040 over MP 268 .460 lift cam Valve head has 318 valves (1.78/1.50) with BB Chevy springs, shaved .100, ported and polished Gm HEI module with electronic distributor Offy intake with Edelbrock 500 (deleted the K&N filter) Clifford headers with 2" dual exhaust Factory 4 speed with McLeod 10" clutch Ford 8.8 Explorer rear (3.73 trac-loc), 225 14/70 tires in back. My best time was 15.75 @ 87 MPH. I know I can go faster with some fiddling. Now the fun begins. I started at 8* initial and ran a 16.2. I bumped it to 10* and ran the 15.7. I went to 12* and ran a 15.8. I haven't put a dial back timing light on it yet, but I was told the mechanical advance is 20*. The carb is two stages lean (8%). I don't know if the bigger valves are enough to go with a richer set up. Any thoughts/advice is appriciated. Thanks again for this website! |
| Author: | Dart270 [ Sun Oct 30, 2005 5:44 am ] |
Sounds like very good progress - congrats! Time to do some jet/rod changes. I found that with my Edel 600 and 500 carbs, they were fastest with pretty close to the stock jets/rods. Lou |
| Author: | 1966 dart wagon [ Wed Nov 02, 2005 10:38 am ] |
| Post subject: | to: Russell Cable |
Russell Cable you said your car runs 15's now and you would like to get into the 14's what are you running |
| Page 2 of 2 | All times are UTC-07:00 |
