It is currently Sun Nov 29, 2026 4:33 pm
Post new topic  Reply to topic  [ 17 posts ]  Go to page Previous 1 2
PostPosted: Wed Dec 01, 2004 7:51 am
The original carb had been completly rebuilt and flow tested, and had been re-jetted for a leaner mix so actually I didn't answer the question that still nags me.
As far as the constant voltage regulator, you make a good point about the fact that it outputs 14.5 volts come hell or high water however unless I were to drain my battery for some reason 14.5 is plenty to keep the system charged. Even under load the old regulator never allowed more than 15V to charge the system anyway.
The reason for going constant voltage is because the ECU actually behaves better when it's input voltage is not all over the map. This is a point that can and has been argued I suppose, but the car runs fine with it. It's not a daily driver, but not a racer either.
Kevin
PostPosted: Sun Dec 05, 2004 12:44 pm
I took the carb yesterday for a rebuild and it is ready to pick up tomorrow morning. It is being re-jetted and metered for a leaner mixture.
Oof. I don't think you're on the right track here. It ran well before, with that carburetor.
remember.....I am using a 77 head, and a 1963 vintage single barrel Carter Ball & Ball. Call me crazy but emission standards being what they were in 63 (Non-existent) vs. 77 (Unleaded gas, advent of emmissions pumps....etc.) had to mean a tigher leaner carb on the 77's.
You're not crazy, but your assumptions are incorrect and as another poster mentioned, your "mechanic's" theory regarding "increased vacuum" is out to lunch.
