It is currently Sat Nov 28, 2026 3:06 pm
Post new topic  Reply to topic  [ 44 posts ]  Go to page Previous 1 2 3 Next
PostPosted: Sun Dec 05, 2004 5:54 pm
Regardless of fuel pressure rating, R9 is made out of rubber that won't get brittle or crack over time due to heat exposure, especially when its bent in tight curves.
PostPosted: Sun Dec 05, 2004 6:01 pm
Egg-zactly! :D
PostPosted: Sun Dec 05, 2004 6:25 pm
[Check carefully; that's probably the price for SAE J30R7 carburetor-type line.
Wrong R9!
I bought 6 feet. 25 bucks. Damned expensive, but worth it if it has fewer problems. After minutes and hours of driving the rubber will be "at" temp. You can only insulate so long under the hood.
Wouldn't Chrysler use the cheapest thing available? Rubber line? Less bending and labor?[/quote]
Sweet Emotion
PostPosted: Sun Dec 05, 2004 6:28 pm
[Regardless of fuel pressure rating, R9 is made out of rubber that won't get brittle or crack over time due to heat exposure, especially when its bent in tight curves.]
Metal won't either.[/quote]
Sweet Emotion
PostPosted: Sun Dec 05, 2004 6:33 pm
Yes, well. After *you* have done fuel temp measurements at the carb with the engine running with metal vs. rubber lines, you can come back and tell us what you've learned.
Your problem, here, is that you're attempting to argue what you think must be the case, and I'm telling you what IS the case.
PostPosted: Sun Dec 05, 2004 6:37 pm
Here's my setup (with the two carbs I have to rebuild)
Nice clean installation of the Offy 5041 twin 1bbl setup. I think you'll find your driveability and running will improve tremendously when you get the crankcase ventillation system hooked up properly. Right now, it looks like you've got no PCV valve on it at all, just a hose from the rear oil cap directly to the PCV inlet port on the intake manifold. That's gonna make it hard to get good starting, idling and performance, because it will act like a giant vacuum leak.
PostPosted: Sun Dec 05, 2004 6:41 pm
Or cap off the manifold port and just run an open element breather on the valve cover.
PostPosted: Sun Dec 05, 2004 6:43 pm
Yeah, but that way is halfassed and causes other problems. PCV is a good thing, not a bad thing.
PostPosted: Sun Dec 05, 2004 6:51 pm
What other problems will it cause? The crankcase will still vent and no vaccum is lost. I thought thats what the whole idea of open element crankcase filters was, to get rid of pcv.
Edit: I'm not saying pcv is a bad thing, I just thought it wasn't necessary with open breathers.
PostPosted: Sun Dec 05, 2004 9:07 pm
"...Nice clean installation of the Offy 5041 twin 1bbl setup..."
Question: Can I install that Offy dual-carb setup on my engine that already has the Clifford headers? I'm running a Clifford intake with a Holly 390cfm 4-bbl now.
'73 Dodge Dart Swinger, /6, Clifford intake, Holley 390 cfm 4-bbl, clifford headers, dual exhaust
PostPosted: Sun Dec 05, 2004 9:57 pm
Hey Slantsix,
I bought the rubber line and I'm going with it. I was just a little ticked I paid so much. Haven't done the measurements and I haven't even driven my Scamp 1 mile yet. Pure conjecture and wild guessing. Peace.
BTW I do appreciate your first hand experience and advice and everyone elses on this site. Saved me hundreds of hours and dollars. So thanks.
Sweet Emotion
PostPosted: Sun Dec 05, 2004 10:23 pm
R9 line is expensive. $25 for 6 feet, thats $4.17/ft. Thats not a great price, but its not terrible either. 5/16" R9 locally here goes for $3-5 as well.
PostPosted: Mon Dec 06, 2004 11:20 am
"Getting rid of PCV" is not a good goal, it's a counterproductive one.
The point I'm trying to make (maybe not very clearly) is that active positive crankcase ventillation is much, much better on a street-driven engine than passive crankcase ventillation, which in turn is much, much better than open ventillation.
Some definitions-
Open ventillation: The crankcase is simply vented direct to atmosphere by means, usually, of an open-element breather cap. This ensures crankcase pressure doesn't build up and blow gaskets and seals or force oil up past the rings, but that's all it does. The crankcase fumes, which are smelly and toxic even on an engine in good condition, simply waft into the engine bay to make a mess (and usually into the passenger compartment via the cowl air intake to stink it up).
Passive crankcase ventillation: This system makes use of a road draft tube which extends from a point above the oil level (usually the valve cover) down to a point below the engine, such that the forward motion of the car generates a draft across the open bottom end of the draft tube, which creates suction in the tube and pulls crankcase vapors out. This system relieves crankcase pressure, too, but it also vents the vapors down and away from the passenger compartment and engine bay. As long as you always go over 30mph and never drive through snow deep enough to clog the draft tube, this system works OK. By circulating fresh air through the crankcase due to the draft (not present with a simple open vent), water vapor and other undesireable gases are flushed out of the crankcase, with the result being that the oil and engine internals stay cleaner, longer.
Positive crankcase ventillation: This system replaces the road draft tube with a hose running from the valve cover to the intake tract, *with a flow control valve in the hose*. This is an enormous improvement over passive or open ventillation, for it ensures a constant clean sweep of fresh air through the crankcase even at idle and low speeds when the open or passive systems do nothing (or next to nothing). Escape of crankcase gases into the engine bay and passenger compartment are virtually completely eliminated. Positive crankcase ventillation also helps combustion efficiency and reduces oil consumption by maintaining slight negative pressure (vacuum) in the crankcase, and keeps the engine oil and internals much cleaner, much dryer, much longer than an open or passive system.
The flow control valve (PCV valve) does several useful things: It reacts to changing engine vacuum to meter the optimal amount of crankcase gas into the intake tract so as to maintain the desireable negative crankcase pressure while not upsetting the fuel/air mixture. The one-way PCV valve also prevents a backfire from reaching the crankcase by slamming shut in response to a sudden rise in intake tract pressure.
Even racers, who as a rule used to run open breathers, have discovered the performance benefits of negative crankcase pressure. Racing PCV systems don't rely on intake vacuum, 'cause usually when racing, there is none! (wide open throttle). Instead, these elaborate systems rely on negative-pressure pulses very far upstream in the exhaust system, and vent the crankcase via special valves to the headers(!).
It is a common but mistaken notion that anything nominally for emission control and identified by a 3- or 4-letter abbreviation simply has to be bad and must be eliminated. A properly-implemented PCV system offers a huge list of real benefits and zero drawbacks.
PostPosted: Mon Dec 06, 2004 11:21 am
"...Nice clean installation of the Offy 5041 twin 1bbl setup..." Can I install that Offy dual-carb setup on my engine that already has the Clifford headers? I'm running a Clifford intake with a Holly 390cfm 4-bbl now.
Yeah, you can, though Dutra Duals are better.
PostPosted: Mon Dec 06, 2004 4:12 pm
Hi Dan,
Yes, I actually have a PCV valve - it's hidden in that big chrome vent cap, and can be removed and replaced. From my experience with Harleys (huge pistons and small crankcase area), I know that negative crankcase pressure is good.
On my Buell (that I don't ride anymore since getting married), I vented to outside the engine, but I installed a special billet one-way valve that's supposed to actually create negative pressure in the crankcase. I was just running a catch can before that - and I can tell you that the bike sounded better and idled smoother with that valve device (that I can't remember the name of).
Amazingly, it didn't puke up as much water/gas/oil emulsion as just a straight catch can did.
1963 Dodge Dart, motor by Doug Dutra, Offenhauser two carb intake, Pertronix, Clifford 6x2, Flowmaster 40's, Erson RV15/295 RDP, head work. Addco anti-sway bar, urethane suspension bushings, KYB's, racing leafs, SSBC discs. Need ZDDP? Get STP.
Users browsing this forum: Bing [Bot] and 12 guests
